Page 5 of 5 1 2 3 4 5
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #3037014
04/25/22 04:13 PM
04/25/22 04:13 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Part 5 – Offset Distributor. Build Notes
I decided to keep the MSD distributor with the old Daytona cast iron engine. That mild engine used a custom advance curve (springs, etc). So, I needed one for the new B1 engine and found a lightly used offset distributor made for Predator heads. It moves the distributor cap away from the head and uses a large diameter cap (Ford style).
1) It has adjustable rotor phasing.
2) The base (with o-ring) is adjustable for shaft length as it clamps to the bearing housing part of the distributor
When I bought it, the tip of the shaft was 4.196” from the base (where it touches the block). I loosened the two allen head bolts that clamp the base to the distributor and installed it in my block with the bronze gear oil pump drive shaft that I am using (Milodon 21525). I pressed the assembly to bottom in the gear tang slot and tightened the allen bolts. I removed it and the zero endplay length was 4.176”. I made a small adjustment to give me 0.007” endplay; resulting in a length of 4.169”.
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #3037016
04/25/22 04:19 PM
04/25/22 04:19 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
FWIW,
I measured my old MSD "billet" distributor and the length sticking out was 4.080"
I measured my friend's new MSD distributor and the length sticking out was 4.106"
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #3037247
04/26/22 12:20 PM
04/26/22 12:20 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have an offset one in my 540" B1 in the Savoy as well. Not any issues with it and I like the larger cap. I usually use front drive distributors for the same reason.
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #3037285
04/26/22 02:27 PM
04/26/22 02:27 PM
A gulag near you.
JohnRR Offline
JohnRR  Offline
A gulag near you.
Originally Posted by 440Jim
I tried making a You-Tube video showing one of my oil system tests.
This is the assembled engine, except one pair of lifters are removed to view the oil flow through the small (0.030"-0.035") hole in the lifter bushings.
I was using a slow (600 rpm max) battery powered hand drill to turn the oil pump, 64 psi with these lifters removed. Nice to know oil pressure exists even with lifters removed.
Plenty of flow though that little hole !
YouTube LINK to oiling test
I also placed a set of pushrods in the lifters (no rocker arms) to make sure it pumped oil to the rockers/heads. Successful, but my video is too dark for a good view. The oil flowed out the rocker end of the pushrods, but did not shoot out like in the lifter bore. There was no pressure on the pushrods except their own weight resting in the lifter cup.
That's a good amount of flow , I had bigger holes put in my bushings, maybe too big looking at this??? I'll have to try this test when I get it together to see how bad it is .
Mainstream Media is the new Pravda
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #3073706
09/02/22 09:11 PM
09/02/22 09:11 PM
West Palm Beach, Florida
Craig J Offline
Craig J  Offline
I apologize if I missed it, but what did you do with the rear seal on this engine? Great detail in you summary, thank you, Craig.
Re: 572 B1 org Part 5 - Build Notes [Re: Craig J] #3074167
09/04/22 10:50 AM
09/04/22 10:50 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Some really good info in this thread. Thanks for posting the oiling videos Jim.
