Duster 340 Ballast Resistor #2994414
12/11/21 06:22 PM
12/11/21 06:22 PM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
I’m looking for a spare ballast resistor. I have a 70 Duster 340 with Mopar electronic ignition. Does anyone know what Ohm values I need or a part number that will work?
Thanks for your help!
Stu.
Re: Duster 340 Ballast Resistor [Re: SSSN8KE] #2994425
12/11/21 06:50 PM
12/11/21 06:50 PM
PA
70Duster Offline
70Duster  Offline
PA
Stu.
With a stock orange box, use a 0.5 ohm ballast resistor.
Re: Duster 340 Ballast Resistor [Re: SSSN8KE] #2994448
12/11/21 08:09 PM
12/11/21 08:09 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Assuming U are using the Mopar aftermarket factory system(#P3690426), orange box and stock coil(#02495531)...
The ballast resistor is 1 Ohm, Mopar #P5206436.
Just my $0.02... wink
Re: Duster 340 Ballast Resistor [Re: 70Duster] #2994454
12/11/21 08:51 PM
12/11/21 08:51 PM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
Thank you! Yes I have the orange box
Re: Duster 340 Ballast Resistor [Re: Sinitro] #2994455
12/11/21 08:52 PM
12/11/21 08:52 PM
Orillia, Canada
SSSN8KE Offline OP
SSSN8KE  Offline OP
Orillia, Canada
Sinitro, thank you!
Re: Duster 340 Ballast Resistor [Re: SSSN8KE] #2994528
12/12/21 09:28 AM
12/12/21 09:28 AM
VA
dragon slayer Offline
VA
Please correct me if I am wrong, but other than the early electronic ignition that used a dual ballast (one for coil and one for the ECU), it is not the box that determines the ballast resistor, but the coil rating. The coil you are using determines the ballast resistor rating.
Re: Duster 340 Ballast Resistor [Re: dragon slayer] #2994551
12/12/21 10:29 AM
12/12/21 10:29 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
You are correct
