Re: Duster 340 Ballast Resistor
[Re: SSSN8KE]
#2994425
12/11/21 06:50 PM
12/11/21 06:50 PM
Posts: 1,643 PA
70Duster
PA
I’m looking for a spare ballast resistor. I have a 70 Duster 340 with Mopar electronic ignition. Does anyone know what Ohm values I need or a part number that will work?
Thanks for your help! Stu. With a stock orange box, use a 0.5 ohm ballast resistor.
[Re: SSSN8KE]
#2994448
12/11/21 08:09 PM
12/11/21 08:09 PM
Posts: 5,447 So Cal
Sinitro
So Cal
Assuming U are using the Mopar aftermarket factory system(#P3690426), orange box and stock coil(#02495531)... The ballast resistor is 1 Ohm, Mopar #P5206436. Just my $0.02... ![wink wink](/ubbthreads/images/graemlins/custom/wink.gif)
[Re: dragon slayer]
#2994551
12/12/21 10:29 AM
12/12/21 10:29 AM
Posts: 6,326 nowhere
Sniper
nowhere
Please correct me if I am wrong, but other than the early electronic ignition that used a dual ballast (one for coil and one for the ECU), it is not the box that determines the ballast resistor, but the coil rating. The coil you are using determines the ballast resistor rating. You are correct
