Attach points for engine lift? #2990682
11/30/21 10:22 PM
11/30/21 10:22 PM
BDW Offline OP
BDW  Offline OP
Where and how is the best way of attaching a harness/chain for lifting a 5.7 with a cherry picker?
Need to get my new 5.7 out of the crate and on an engine stand.
Thx
Re: Attach points for engine lift? [Re: BDW] #2990688
11/30/21 10:35 PM
11/30/21 10:35 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
If it has the brackets/accessories on the front, there should be a long stud above the water pump just hanging out there by itself. Thats the front attaching point. The other is under the intake. Its a threaded hole in the block, in the "lifter valley" where the mds plugs/solenoids are residing
Re: Attach points for engine lift? [Re: moparjim79] #2990825
12/01/21 12:14 PM
12/01/21 12:14 PM
IL
furious70 Offline
furious70  Offline
IL
They do make various lift brackets to hook the back of a head, those 2 intake valley bolts, and a front accessory drive bolt.
I was nervous, but I did lift a core 5.7 with a 727 (dry and no converter) up and out of my Coronet with just the 2 valley bolts and it held. I typically don't do a carb plate, but it felt similar.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Attach points for engine lift? [Re: furious70] #2991092
12/01/21 11:32 PM
12/01/21 11:32 PM
BDW Offline OP
BDW  Offline OP
I'm fuzzy, so does the intake have to come off for the back of engine attach point?
It took me 2 days to get the motor out of the shipping crate and onto a dolly.
I used the front stud mentioned, and 2 of the transmission bolts for the back.
That most likely won't work when I go to drop it in car.
Re: Attach points for engine lift? [Re: BDW] #2991233
12/02/21 12:13 PM
12/02/21 12:13 PM
IL
furious70 Offline
furious70  Offline
IL
yes you need to take the intake off to get to the valley bolts. it's plastic so it's easy to damage too with a chain over top.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Attach points for engine lift? [Re: moparjim79] #2991430
12/02/21 10:35 PM
12/02/21 10:35 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
[color:#CC6600][/color]
Originally Posted by moparjim79
If it has the brackets/accessories on the front, there should be a long stud above the water pump just hanging out there by itself. Thats the front attaching point. :)The other is under the intake. Its a threaded hole in the block, in the "lifter valley" where the mds plugs/solenoids are residing grin
[color:#CC6600]
Re: Attach points for engine lift? [Re: moparjim79] #2992114
12/04/21 10:46 PM
12/04/21 10:46 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
It sure would be great to see a picture of this.
Re: Attach points for engine lift? [Re: Kern Dog] #2992392
12/05/21 09:15 PM
12/05/21 09:15 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Re: Attach points for engine lift? [Re: Kern Dog] #2992397
12/05/21 09:37 PM
12/05/21 09:37 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Here is a shot from my 6.4( if this pic doesn't show i apologize)- the holes i mentioned are also used to anchor the mds harness
Re: Attach points for engine lift? [Re: Kern Dog] #2992399
12/05/21 09:41 PM
12/05/21 09:41 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
Here's a shot from an ebay ad, I just typed in 5.7 hemi engine block
Re: Attach points for engine lift? [Re: moparjim79] #2992419
12/05/21 10:48 PM
12/05/21 10:48 PM
BDW Offline OP
BDW  Offline OP
Thx, that definitely clears things up.
That RMS lift bracket looks super nice, can't justify $200 for something I'll only use once.
I'll have to McGyver something up with chains and a level loader.
Also saw these, again very nice, but a little pricey
https://www.schwartzperformance.com/product/gen-3-hemi-engine-lifting-brackets-5-7-6-1-6-2-6-4/
Re: Attach points for engine lift? [Re: BDW] #2992427
12/05/21 11:48 PM
12/05/21 11:48 PM
Granite Bay CA
Kern Dog Offline
Kern Dog  Offline
Granite Bay CA
I am amazed that those tiny valley bolt holes could support the weight.
Re: Attach points for engine lift? [Re: BDW] #2992454
12/06/21 05:21 AM
12/06/21 05:21 AM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
I made one out of some scrap steel when I needed to do the engine swap on the 2004 Durango.
I've made some small changes since these pics were taken.
I changed where the front attaching points are to where it uses the bolt holes where the intake bolts on and another bolt that connects it to the timing cover at the center.
I literally put the tab at the center through the slot that normally has the chain coming out of it on the engine hoist boom.
Since the engine sits so far under the cowl I needed to connect it as low as possible on the engine.
I pulled the engine out of the Durango without taking the hood off.
Re: Attach points for engine lift? [Re: SNK-EYZ] #2992522
12/06/21 11:53 AM
12/06/21 11:53 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
At one time I think Motion Raceworks sold a lift plate for the G3. I saw them post something recently alluding to the fact that they are about to release a new lineup of G3 stuff so maybe that will come back.
68 Barracuda Formula S 340
Re: Attach points for engine lift? [Re: Kern Dog] #2992664
12/06/21 07:33 PM
12/06/21 07:33 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
I've always thought and cannot help to cringe when I see someone lift an engine with a carb plate,especially on an aluminum intake,, but its done everyday.
Re: Attach points for engine lift? [Re: BDW] #2992854
12/07/21 12:15 PM
12/07/21 12:15 PM
IL
furious70 Offline
furious70  Offline
IL
I did use my leveler in that fashion once. But I swapped from car to truck accessory plate on to test fit other things and that doesn't have the stud to mount to in the front. That's when I had to just use the valley bolts.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Attach points for engine lift? [Re: BDW] #2992855
12/07/21 12:17 PM
12/07/21 12:17 PM
IL
furious70 Offline
furious70  Offline
IL
Having taken log manifolds on and off while in my 69 Coronet - it's a PITA. I wouldn't want these brackets which force you to do the manifold/header R&R in the car.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Attach points for engine lift? [Re: furious70] #2992970
12/07/21 06:18 PM
12/07/21 06:18 PM
BDW Offline OP
BDW  Offline OP
What thread and length bolts are needed for the valley?
Metric? Was surprised the bolts on front of engine are metric and the trans attach points are SAE
Re: Attach points for engine lift? [Re: BDW] #2993890
12/09/21 11:48 PM
12/09/21 11:48 PM
racine,wi
70gtx1 Offline
70gtx1  Offline
racine,wi
I used these, they worked great!! https://www.ebay.com/itm/125001565795?hash=item1d1aac8663:g:NV0AAOSwWxNY2sjv
Re: Attach points for engine lift? [Re: 70gtx1] #2994130
12/10/21 06:32 PM
12/10/21 06:32 PM
BDW Offline OP
BDW  Offline OP
Looks interesting, did you put on diagonally and lift in middle?
Problem is my 5.7 motor doesn’t have a threaded hole on back side off head?
Only thread holes are on front
591A2E25-0569-489A-834A-D55AA278212D.jpegScreenshot_20211210-173400_kindlephoto-1611529.png
