BAM DLC bushed lifters and lifter bore bushed block #2992228
12/05/21 12:33 PM
12/05/21 12:33 PM
Southington Ct.
turbobitt Offline OP
Southington Ct.
First, has anyone had any real world experience with these DLC steel bushed lifters? I am debating on using these in a marine/endurance application where durability is a must..
Second, Is there a special part number for bushed blocks(with small oil feed drilling) such as a BB chevy bodied lifter ?
Third, a suggested where to buy....
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: BAM DLC bushed lifters and lifter bore bushed block [Re: turbobitt] #2992613
12/06/21 04:46 PM
12/06/21 04:46 PM
Tulsa, Ok
WadeMetzinger Offline
Tulsa, Ok
I've been using them for 2 years now, used to run Isky bushed lifters until I heard from a very well respected engine builder about BAM's DLC coated lifters and how much better they would be. He's been using them for 3 or so years now in all sorts of high end motors and hasn't had any failures. He told me it may be the last lifter I buy. They are cost less than the Isky bushed lifters. I just put a set in one of my customers motors.
I think they only make 1 for BB mopar.
Here's who I get mine from, he can tell you more about them as he uses lots of them:
Matt Driskell - www.driskellent.com
mattdriskell@driskellent.com
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: BAM DLC bushed lifters and lifter bore bushed block [Re: turbobitt] #2992648
12/06/21 06:06 PM
12/06/21 06:06 PM
NC
440Jim Offline
440Jim  Offline
NC
I found this on the web Link to BAM website
It does say available in needle bearing, bronze bushed, or steel DLC bushed.
Click on the thumbnail pic of the part numbers.
Re: BAM DLC bushed lifters and lifter bore bushed block [Re: 440Jim] #2992654
12/06/21 06:44 PM
12/06/21 06:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
My next set of lifter will be BAM DLC coated. The only reason I did not use them on the -1 or Victor engine projects was the .210 intake lifter offset vs. Isky's .180. I know, .030, big deal. That .210 offset lister seat is *really* close to the edge in a .904. That said the current 451 project is standard port with standard rocker arm offsets so that will not be a concern.
DLC coating is amazing stuff. I have DLC valve locks in a few applications and they are really easy to work with and still looking like new.
Re: BAM DLC bushed lifters and lifter bore bushed block [Re: Jeremiah] #2992717
12/06/21 10:06 PM
12/06/21 10:06 PM
NC
440Jim Offline
440Jim  Offline
NC
Yes, it is "close". But my mock-up with B1 heads (offset T&D rockers), with 7/16" tapered pushrods (about 3/8" dia 1" from tip) worked out just fine.
Re: BAM DLC bushed lifters and lifter bore bushed block [Re: turbobitt] #2993058
12/07/21 10:09 PM
12/07/21 10:09 PM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
No real world experience yet but I purchased 2 sets for a couple builds both dlc coated. Just add BB1 to whatever pn to get the dlc coated. I called Brad directly at BAM to confirm availability and part numbers in mid Nov. Then ordered thru Hughes because I had a few other items to get... Pretty painless. They actually shipped this morning but would have been sooner BAM shut down over Thanksgiving.
Re: BAM DLC bushed lifters and lifter bore bushed block [Re: 440Jim] #2993360
12/08/21 09:03 PM
12/08/21 09:03 PM
Southington Ct.
Southington Ct.
Anyone know why there is a Hemi Specific P/N 2016-16-X1 ?
AG.
Re: BAM DLC bushed lifters and lifter bore bushed block [Re: turbobitt] #2993515
12/09/21 10:17 AM
12/09/21 10:17 AM
Idaho
boomerodell Offline
boomerodell  Offline
Idaho
They are taller to help with hemi rocker geometry.
