Lower dash panels for the 95 Ram #2932494
06/12/21 01:50 PM
06/12/21 01:50 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
You no the peace below the steering column anyone remanufacturing a replacement (better quality peace than the factory did) yet?
Re: Lower dash panels for the 95 Ram [Re: racerx] #2932541
06/12/21 04:09 PM
06/12/21 04:09 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you're talking about the knee blocker or knee bolster a google search doesn't show anyone having them new.
Re: Lower dash panels for the 95 Ram [Re: SNK-EYZ] #2932640
06/12/21 09:43 PM
06/12/21 09:43 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Yep ...that's it the one from the factory were cheap plastic whiney
Does any of the newer rams interchange ? work
Re: Lower dash panels for the 95 Ram [Re: racerx] #2932718
06/13/21 08:32 AM
06/13/21 08:32 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I have two second gens and both are in original condition. You should not have a problem finding one in a junk yard, ebay or craigs list.
Re: Lower dash panels for the 95 Ram [Re: racerx] #2932803
06/13/21 12:59 PM
06/13/21 12:59 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
What problem are you having with them?
They're all going to be plastic.
94 through 2001 (2002 HD) are "probably" all be the same.
Re: Lower dash panels for the 95 Ram [Re: SNK-EYZ] #2932997
06/13/21 10:38 PM
06/13/21 10:38 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
They are deteriorating from age the truck only have a 133,000 i thought Dodge would have better plastics on there newer trucks.
Re: Lower dash panels for the 95 Ram [Re: racerx] #2932998
06/13/21 10:40 PM
06/13/21 10:40 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Maybe i'll just check the salvage yards.
Re: Lower dash panels for the 95 Ram [Re: racerx] #2934824
06/19/21 12:13 PM
06/19/21 12:13 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
Age is not the factor but heat/sun is.Heat/sun will make the plastic brittle over time. If you look at the junks yards try to find one that doesn't have sun faded interior. If buying off ebay choose someone that doesn't live in a hot sun belt location.
Re: Lower dash panels for the 95 Ram [Re: Moparite] #2934967
06/20/21 07:16 AM
06/20/21 07:16 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Originally Posted by Moparite
Quote
iagree I had this truck sense 96 it did spend much of it's time outside, now it's in the garage wave
Re: Lower dash panels for the 95 Ram [Re: racerx] #2935936
06/23/21 09:55 AM
06/23/21 09:55 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I won’t do any dash work on anything that old at work (95-05).... to much liability on destroying a lot of unobtanium
Re: Lower dash panels for the 95 Ram [Re: J_BODY] #2941080
07/08/21 08:28 AM
07/08/21 08:28 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Does the later model panels use a clip? Mine has screws.
Re: Lower dash panels for the 95 Ram [Re: racerx] #2991176
12/02/21 09:33 AM
12/02/21 09:33 AM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
bump for this.. sense the weather is suppose to be nice heading out today, the ones that i have seen were clips.
Re: Lower dash panels for the 95 Ram [Re: racerx] #2991736
12/03/21 05:13 PM
12/03/21 05:13 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Well found out the 98's are different ,they were shorter 18" wide verse the 95 which are 21" wide the 98 also use clips and the 94-95 use screws. realmad
