Re: Lower dash panels for the 95 Ram
[Re: racerx]
#2932803
06/13/21 12:59 PM
06/13/21 12:59 PM
Posts: 10,115 A Red State
SNK-EYZ
A Red State
Yep ...that's it the one from the factory were cheap plastic Does any of the newer rams interchange ? What problem are you having with them? They're all going to be plastic. 94 through 2001 (2002 HD) are "probably" all be the same.
[Re: SNK-EYZ]
#2932997
06/13/21 10:38 PM
06/13/21 10:38 PM
Posts: 4,049 Mo.
racerx
Mo.
Yep ...that's it the one from the factory were cheap plastic Does any of the newer rams interchange ? What problem are you having with them? They're all going to be plastic. 94 through 2001 (2002 HD) are "probably" all be the same. They are deteriorating from age the truck only have a 133,000 i thought Dodge would have better plastics on there newer trucks.
[Re: racerx]
#2934824
06/19/21 12:13 PM
06/19/21 12:13 PM
Posts: 948 rust belt
Moparite
rust belt
They are deteriorating from age Age is not the factor but heat/sun is.Heat/sun will make the plastic brittle over time. If you look at the junks yards try to find one that doesn't have sun faded interior. If buying off ebay choose someone that doesn't live in a hot sun belt location.
