Page 3 of 5 1 2 3 4 5
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2989339
11/26/21 02:45 PM
11/26/21 02:45 PM
PA
Harry's Taxi 2 Online content
Harry's Taxi 2  Online Content
PA
I'd suggest verifying cam specs.
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: 572 B1 org Part 5 - Build Notes [Re: Harry's Taxi 2] #2989449
11/26/21 10:08 PM
11/26/21 10:08 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Did you miss this post on Nov 18th?
[url=https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2986438/re-572-b1-org-part-5-build-notes.html#Post2986438][/url]
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2989451
11/26/21 10:15 PM
11/26/21 10:15 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I was hoping to have the heads torqued today, but it didn't happen.
I have the heads on the studs, with head gasket, etc. But tomorrow will have to be the day to lube and torque all the head stud nuts.
I was happy to finish the setup of the heads with proper valve spring heights, seals, etc. Lots of little details seem to take me a lot of time. But that makes me happy. wrench
I did buy a new crank/damper bolt, some 10-32 set screws , and new spark plugs on my way home from lunch today.
The set screws go in the head holes that can be used to restrict rocker oiling from the block to the rockers/heads. They are under the rocker stands. So if somebody wanted to remove the paired T&D rockers and put the long single shaft rockers on these heads (which oil from the block), they would not have to pull the heads, just the rockers and replace these solid set screws.
But I am using pushrod oiling... hence the solid set screws (instead of drilled restrictors.) These are in the heads, not the block (which can be restricted/plugged also, since the block is threaded.)
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2989470
11/26/21 11:00 PM
11/26/21 11:00 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
This is one of the little details I had to do today.
Cut off the useless "tab" on the Cometic head gaskets. Which can interfere with pushrods on some applications.
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2989496
11/27/21 03:12 AM
11/27/21 03:12 AM
iagree up wrench
I've had to do that on a lot of head gaskets wrench
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2989506
11/27/21 07:32 AM
11/27/21 07:32 AM
PA
PA
Apparently i did.....sorry to say that i don't follow your every post. i have bought 4 cams lately that have been from 2-6 degrees off on intake lobes and 2 of those are from the same grinder you used.
You're welcome for the reminder just the same.
Re: 572 B1 org Part 5 - Build Notes [Re: Harry's Taxi 2] #2989531
11/27/21 10:40 AM
11/27/21 10:40 AM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Thanks for letting me know of your experience. I bought this cam from another racer that never used it. It came in a package deal with my B1 heads, intake, valve covers, valley plate, etc.
I measured the lobes using a dial indicator type follower with 0.810" dia. My roller lifters (Comp 892 offset seats, pushrod oiling) have 0.800" dia wheels. If the dia is significantly different, it can change lobe numbers slightly.
Both intake and exhaust measured 1-2 degrees more than the cam card. I actually measured 5 intake and exhaust lobes (different cylinders).
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2989914
11/28/21 05:20 PM
11/28/21 05:20 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
One build note when torqueing the heads.
Those 1.63" dia springs don't leave much room to torque the heads. Especially the very center stud/nut between two springs
I used my 3/8 drive socket with a 3/8 to 1/2 adapter to my torque wrench. My 1/2 drive socket didn't fit between them.
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2990147
11/29/21 01:07 PM
11/29/21 01:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We turn down a socket to get to the center head stud nuts. Yep the tab is defintely useless, and the placement of the damn rivets smile
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2992221
12/05/21 12:19 PM
12/05/21 12:19 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Part 5 – Intake Gaskets. Build Notes
This note may be fairly specific to the porting on my heads/intake, but the gasket info may be of interest to other B1 head users.
I had previously bought gaskets from Koffel's Place, and those are 1.60 x 2.66. Those are smaller than the ports on my heads.
I bought these intake manifold gaskets from FlatOut Gaskets and they fit my head ports very well. They are part number 8185 and their catalog lists the size as 1.75 x 2.82
FlatOut makes lots of different gaskets, this link is to the various thicknesses of the #8185 FlatOut Gaskets 8185
The gaskets have two corners clipped, and they fit my heads with those corners on the bottom! This way, the top of the gasket aligns well with the valve cover sealing surface.
And just like the Koffel's gaskets, I need to trim the area under the bolt holes for the B1 valley plate.
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2992251
12/05/21 01:22 PM
12/05/21 01:22 PM
moparx Offline
moparx  Offline
nice gaskets and pretty reasonable pricing as well. up
beer
Re: 572 B1 org Part 5 - Build Notes [Re: moparx] #2992285
12/05/21 03:00 PM
12/05/21 03:00 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I like the FlatOut gaskets. And several choices even a steel core.
FWIW, this pic shows the port misalignment if I put the cropped corners UP. The gasket hole centerline is 0.030" different than the port centerline.
So flipping the gasket moves the port opening 0.060"
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2992296
12/05/21 03:32 PM
12/05/21 03:32 PM
AndyF Offline
AndyF  Offline
You should send those pictures to the mfg and see what they say. They might have their drawing wrong or they might not know. The aftermarket is full of parts that are built wrong because somebody made an error and nobody ever pointed it out.
Re: 572 B1 org Part 5 - Build Notes [Re: AndyF] #2992305
12/05/21 04:04 PM
12/05/21 04:04 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
I will do that. But the shop that ported my heads (before I bought them) may have moved the ports too. But I just thought the gasket hole centerline would be the same as the gasket port centerline.
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2992355
12/05/21 06:31 PM
12/05/21 06:31 PM
AndyF Offline
AndyF  Offline
Does the gasket line up with the ports in the intake? If all three parts line up together then you have a winner. I don't know what the cut corners are for. Maybe they are supposed to go down but that does seem odd.
Re: 572 B1 org Part 5 - Build Notes [Re: 440Jim] #2992366
12/05/21 07:11 PM
12/05/21 07:11 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
I built a 572 several years ago using 572-13 heads and a Bill Mitchell/Mopar aluminum block.
The heads used Jesel rockers and I thought I’d be clever and pushrod oil with the 892 lifters.
As it turned out, the Chevy oriented oil holes in the lifters lined up perfectly with the oil feed hole in the lifter bushing with the .484 lobe lift cam with it on the base circle.
When I went to prime the oil system, as soon as the drill started to lug down from the load of pumping the oil....... oil shot out of the top of a few of the adjuster screws about 20ft across the shop.
The correct oil hole orientation in the lifter for a Mopar is to have them parallel to the axle...... not perpendicular.
For proper oil “metering” to the top end with edge orifice oiling type lifters, the pressurized oil in the oil band squeezes between the lifter bore and the lifter body to get into the pushrod feed hole above the band.
In my situation, with the oil hole in the lifter bore/lifter body lined right up with each other, I had totally unrestricted oil to the top end whenever the lifter was close to being on the cams base circle.
Which wouldn’t have been good at all.
So, I took the path of least resistance........ 87019 lifters(892’s with no oil hole) and spray bar valve covers.
Jim, If you haven’t verified this isn’t a problem on your build, I wouldn’t wait until the last thing to check it.
On my build, even running the drill very slow resulted in oil just gushing out of any rocker that was nearly closed.
Re: 572 B1 org Part 5 - Build Notes [Re: AndyF] #2992408
12/05/21 10:02 PM
12/05/21 10:02 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Andy,
The intake runners are tapered toward the heads. So at the intake manifold, the ports are smaller then the large CNC ported heads. Although the previous owner did open up the intake manifold some, the rest of the transition occurs in the ~0.75" thick RB intake manifold spacers. My intake manifold exit is actually larger than the Koffel's gaskets, but not as big as the heads. Remember, the B1 intake fits a low deck block and the RB spacers are used for a RB block.
Fast68plymouth,
I have done lots of measurements on the BMP block lifter bore bushing 0.035" oil hole, the cam base circle, and the Comp 892 lifter oil hole. That is an entire topic on its own.
Thanks for the heads-up. Just like my KB motor, I will prime the system after it is all together to see what the rocker oiling looks like. Fingers crossed.
I have T&D rockers, rather than Jesel. FWIW
The cam I have for this engine has a slightly different base circle diameter, than the one on my buddies 440-SR headed engine with BMP aluminum block. But he used Indy oil lines, not pushrod.
I used the same Comp lifters on my last 440-1 heads and KB aluminum block engine and the head oiling was perfect. But there are lots of differences....
The valve covers that came with my heads have spray bars if that is needed. But if the lifters/pushrods put too much oil to the heads, it will require changes. Ugh!
Re: 572 B1 org Part 5 - Build Notes [Re: fast68plymouth] #2992412
12/05/21 10:19 PM
12/05/21 10:19 PM
AndyF Offline
AndyF  Offline
I had an oiling issue when using Crower roller lifters but I never had any issue using the Comp AMC lifters. It is something to always double check though. All depends how the lifter is getting the oil.
Re: 572 B1 org Part 5 - Build Notes [Re: AndyF] #2992493
12/06/21 10:22 AM
12/06/21 10:22 AM
So. Burlington, Vt.
So. Burlington, Vt.
The Comp AMC lifters have the pushrod oil feed hole in the correct position for a Mopar....... parallel with the axle.
Re: 572 B1 org Part 5 - Build Notes [Re: fast68plymouth] #2994982
12/13/21 05:01 PM
12/13/21 05:01 PM
NC
440Jim Offline OP
440Jim  Offline OP
NC
Part 5 – Water Pump Housing to Jesel Belt Drive. Build Notes
A typical water pump housing will not clear the Jesel Belt Drive. The housing contacts the center of the cam pulley (adapter/nut area) leaving a gap about 3/16” between the block and the housing. Since I am using a 1/4” thick front engine plate (and a midplate between engine & trans), everything will clear.
