FBO plate, good or bad
#2989900
11/28/21 04:35 PM
11/28/21 04:35 PM
RapidRobert
iirc someone said the center hole was too big & caused a problem. I could weld/file the OE slots if thats the way I need to go. Thank you for your time.
Re: FBO plate, good or bad
[Re: lewtot184]
#2989950
11/28/21 07:18 PM
11/28/21 07:18 PM
RapidRobert
Alright, it sounds like it is OK if you go by what the light shows (& I can live with that) thanks guys. RR
[Re: RapidRobert]
#2990076
11/29/21 09:16 AM
11/29/21 09:16 AM
Posts: 3,916 usa
lewtot184
usa
Alright, it sounds like it is OK if you go by what the light shows (& I can live with that) thanks guys. RR you need to measure the plates or you'll end up going circles with this.
[Re: topside]
#2990222
11/29/21 04:42 PM
11/29/21 04:42 PM
Posts: 3,916 usa
lewtot184
usa
Yikes - either I got lucky, or the manufacturing changed, or I just cluster-effed my way through and got REAL lucky. I bought the dist from FBO with the plate installed, now that I think of it. i would imagine fbo set your distributor up on a distributor machine so any needed corrections would have been done at the vendor. unless you're assembling your own stuff you'd never know. and who knows maybe i have screwed up ones? nevertheless they should be checked for accuracy.
[Re: lewtot184]
#2990512
11/30/21 02:48 PM
11/30/21 02:48 PM
Posts: 19,398 north of coder
moparx
i have welded up the slots many times, and have had great success doing so. the one thing that buggs me however, is removing the internal snap ring/spring under the rotor. i finally made a set of pliers that fit the diameter of the "upward pointing" ears, so no more fiddling with two tiny screwdrivers to get that thing out ! i came across a couple of those FBO plates quite a while ago, but i haven't tried to do anything with them. i need to build a distributor for my charger, but i haven't decided if i will use a chrome box, 6AL, pertronix, or a gm HEI mounted under the housing. i also have an offshore distributor i picked up at a swap meet one time for $5.00, and it has a ball bearing shaft in it. i might fab up some factory style guts for it, and experiment with that.
[Re: moparx]
#2990670
11/30/21 10:06 PM
11/30/21 10:06 PM
Posts: 43,163 Bend,OR USA
Cab_Burge
