FBO plate, good or bad #2989900
11/28/21 04:35 PM
11/28/21 04:35 PM
RapidRobert Offline OP
iirc someone said the center hole was too big & caused a problem. I could weld/file the OE slots if thats the way I need to go. Thank you for your time.
Re: FBO plate, good or bad [Re: RapidRobert] #2989913
11/28/21 05:14 PM
11/28/21 05:14 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Mine was fine. Bought a few years ago, car has since moved on to get another.
Re: FBO plate, good or bad [Re: topside] #2989936
11/28/21 06:59 PM
11/28/21 06:59 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the slots are way off on the two i have. only thing i can figure is they used .010" for a degree when it should be .0154" of travel for each degree. once that's figured out you're ok. don't trust the numbers on them!!!!!!!
Re: FBO plate, good or bad [Re: lewtot184] #2989950
11/28/21 07:18 PM
11/28/21 07:18 PM
Alright, it sounds like it is OK if you go by what the light shows (& I can live with that) thanks guys. RR
Re: FBO plate, good or bad [Re: RapidRobert] #2990076
11/29/21 09:16 AM
11/29/21 09:16 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
you need to measure the plates or you'll end up going circles with this.
Re: FBO plate, good or bad [Re: RapidRobert] #2990110
11/29/21 11:12 AM
11/29/21 11:12 AM
Alberta
rustbuckett68 Offline
Alberta
Filled the slots in mine with JB weld epoxy. Let it cure good, used a chainsaw file to get the same measurement side to side. Also figured out the degrees and slot length which turned out pretty accurate. Was about six years ago, and still working.
Re: FBO plate, good or bad [Re: rustbuckett68] #2990117
11/29/21 11:40 AM
11/29/21 11:40 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
with the plates i have a marked10 is actually 6, 12 is 7, 14 is 8.5, 16 is 10, 18 is 11. good idea; poor execution.
Re: FBO plate, good or bad [Re: lewtot184] #2990134
11/29/21 12:24 PM
11/29/21 12:24 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Yikes - either I got lucky, or the manufacturing changed, or I just cluster-effed my way through and got REAL lucky.
I bought the dist from FBO with the plate installed, now that I think of it.
Re: FBO plate, good or bad [Re: topside] #2990144
11/29/21 12:59 PM
11/29/21 12:59 PM
moparx Offline
moparx  Offline
can the plate be installed upside down ? shruggy
if so, what happens then ? [as far as degrees marked]
beer
Re: FBO plate, good or bad [Re: moparx] #2990221
11/29/21 04:38 PM
11/29/21 04:38 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
beer
doesn't make any difference the slots are straight.
Re: FBO plate, good or bad [Re: topside] #2990222
11/29/21 04:42 PM
11/29/21 04:42 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i would imagine fbo set your distributor up on a distributor machine so any needed corrections would have been done at the vendor. unless you're assembling your own stuff you'd never know. and who knows maybe i have screwed up ones? nevertheless they should be checked for accuracy.
Re: FBO plate, good or bad [Re: RapidRobert] #2990293
11/29/21 09:26 PM
11/29/21 09:26 PM
what i know of the old owner I wouldn't ask him for the time of day, let alone use anything he had something to do with in a car, let alone a race car that could hurt me when a part fails twocents work
I do weld up the stock slots and then redo them to get the curve I want up wrench scope weld up
Re: FBO plate, good or bad [Re: Cab_Burge] #2990395
11/30/21 09:10 AM
11/30/21 09:10 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
welding the slots was the old tried and true way to reduce distributor degrees. a distributor machine is a very big help in setting up the curve. keep in mind that .015" of slot length is one distributor degree. the guide pin in the centrifugal weight is very close to .250". a person could easily due the math to figure out the distributor degrees they want and have. i don't know why i even bought those plates. i've got enough parts and experience with this to do anything i want.
Re: FBO plate, good or bad [Re: lewtot184] #2990512
11/30/21 02:48 PM
11/30/21 02:48 PM
moparx Offline
moparx  Offline
i have welded up the slots many times, and have had great success doing so.
the one thing that buggs me however, is removing the internal snap ring/spring under the rotor. i finally made a set of pliers that fit the diameter of the "upward pointing" ears, so no more fiddling with two tiny screwdrivers to get that thing out !
i came across a couple of those FBO plates quite a while ago, but i haven't tried to do anything with them.
i need to build a distributor for my charger, but i haven't decided if i will use a chrome box, 6AL, pertronix, or a gm HEI mounted under the housing.
i also have an offshore distributor i picked up at a swap meet one time for $5.00, and it has a ball bearing shaft in it. i might fab up some factory style guts for it, and experiment with that.
beer
Re: FBO plate, good or bad [Re: moparx] #2990581
11/30/21 06:10 PM
11/30/21 06:10 PM
Tucson,AZ
Remow2112 Offline
Remow2112  Offline
Tucson,AZ
It is a shame the quality has gone down. Used the plate from the original owner on several builds. Always was dead on in my testing.
Re: FBO plate, good or bad [Re: moparx] #2990670
11/30/21 10:06 PM
11/30/21 10:06 PM
the one thing that buggs me however, is removing the internal snap ring/spring under the rotor. i finally made a set of pliers that fit the diameter of the "upward pointing" ears, so no more fiddling with two tiny screwdrivers to get that thing out !beer
I have several sets of thin needle nose pliers that I have used to pull the spring steel wire retainer out, it usually bends them some but I straighten them out and use two narrow thin screw drivers to reinstall that retainer when I'm done wrench weld up
