69 HP 440 #2989879
11/28/21 04:04 PM
11/28/21 04:04 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Just checked out this 69 440 HP in a 71 RR,is the build date 8/5/69 making it a late build eng.
Re: 69 HP 440 [Re: 71GTX471] #2989887
11/28/21 04:19 PM
11/28/21 04:19 PM
Lansing, MI
70gtx440dana Offline
Lansing, MI
Looks like E 440......Likely 8 5 68...making it very early 69 engine.
70 Road Runner 383-4 4 speed FJ5 & black guts
70 Charger R/T 440-4 4 speed FJ5 & white guts
Re: 69 HP 440 [Re: 70gtx440dana] #2989898
11/28/21 04:32 PM
11/28/21 04:32 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Hard to tell for sure if that is an E or an F?
If it is an E, the assembly year would be 1968. (the 1969 model year started in August 1968)
If it has a full or partial VIN down low on the passenger side, can you get a photo?
Re: 69 HP 440 [Re: Alaskan_TA] #2989916
11/28/21 05:25 PM
11/28/21 05:25 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
Yes its an E440 69 model year,cant get to the vin# yet need a floor jack & stands to get closer to see the vin#,cars been setting many years outside & is very low to the ground,I guess the vin# would help distinguish weather early or late build,owner states that when he bought it the seller said it was a six pack eng.
Re: 69 HP 440 [Re: 71GTX471] #2989938
11/28/21 07:00 PM
11/28/21 07:00 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Originally Posted by 71GTX471
Yes its an E440 70 model year,cant get to the vin# yet need a floor jack & stands to get closer to see the vin#,cars been setting many years outside & is very low to the ground,I guess the vin# would help distinguish weather early or late build,owner states that when he bought it the seller said it was a six pack eng.
E is a 69 not 70
Re: 69 HP 440 [Re: 71GTX471] #2989939
11/28/21 07:01 PM
11/28/21 07:01 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
E 440
8 5 HP
E = 1969 model year
440 = 440 cuin
8 5 = August 5, 1968
HP = MAGNUM, TNT, SUPER COMMANDO
Re: 69 HP 440 [Re: 6bblgt] #2990059
11/29/21 06:32 AM
11/29/21 06:32 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I don’t think an August of 68 assembly date on the motor would be in line for even the first of the A12 cars. I’ve never heard of one having that early of a assembly date. The vin number would tell you.
Re: 69 HP 440 [Re: fastmark] #2990087
11/29/21 09:54 AM
11/29/21 09:54 AM
Wheatfield, NY
Cuda340 Offline
Cuda340  Offline
Wheatfield, NY
I would be very interested in that block if it is good. Looking to date code my car.... I wonder what the VIN is???? My car happens to be a six pack!!!!!!! I just noticed it was an E440.... My bad.... Cool find.
Re: 69 HP 440 [Re: 71GTX471] #2990181
11/29/21 02:20 PM
11/29/21 02:20 PM
What is the casting date on that block?
Re: 69 HP 440 [Re: CSK] #2990225
11/29/21 05:22 PM
11/29/21 05:22 PM
Harriman NY
71GTX471 Offline OP
71GTX471  Offline OP
Harriman NY
E is a 69 not 70 [/quote
I knew that brain fart.
Cab haven't been able to get underneath it yet.
