Re: Neutral Safety Switch/Reverse Lamp Harness?
[Re: rarefish]
#2989653
11/27/21 06:02 PM
11/27/21 06:02 PM
Posts: 3,923 Richmond, Indiana
19swinger70
Richmond, Indiana
That could be from a lot of different cars. my only guess is that it is from a '68 and newer car - because my '67 Barracuda did not have the 3 pin connector for the trans, it only had the 1 pin for the neutral safety switch. (The other 2 pins are for the backup lights - which on my '67 were triggered by a switch on the base of the steering column OR on the shifter if a 4spd)
1970 340 swinger. sublime 1967 barracuda fastback BB 55 Plymouth Project
[Re: rarefish]
#2989770
11/28/21 08:43 AM
11/28/21 08:43 AM
Posts: 6,095 Valencia, España
NachoRT74
Valencia, España
Pretty sure 71 ( or 73 ) and lates A Body. They use to get an extension harness to reach the bulkhead and Starter relay. E bodies and 71-74 B bodies got them with the plug straight to the bulkhead and I think pre 70 cars get the NSS harness with free terminals to be inserted into the wiper motor plug.
dunno if maybe some C body.
But allways pre 75 because by 75, the color setup of the harness changed to violet, black and brown/yellow wires.
