What are you using for new Magnum heads these days? #2986173
11/17/21 06:49 PM
11/17/21 06:49 PM
dogdays Offline OP
dogdays  Offline OP
Hello,
I've been out of commission for a few years and am thinking about swapping my home ported 302 heads for Mag heads when I redo my 318. Back in the day, the EngineQuest heads were the cat's whiskers, but I've heard (those dangerous words) that the "new" EQ heads are not performance heads any more. So, what are people using for new Mag head builds?
How about it? Where do I go?
R.
Re: What are you using for new Magnum heads these days? [Re: dogdays] #2986192
11/17/21 07:34 PM
11/17/21 07:34 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
EQ makes two Magnum heads. Standard (318A) and performance (318B).
Flow numbers
https://enginequest.com/enginequest/cylinder-heads/flow-numbers/
The heads themselves, bare.
https://www.ebay.com/itm/143965139173?hash=item2184fdb0e5:g:tA0AAOSw33tfBJF4
Re: What are you using for new Magnum heads these days? [Re: Sniper] #2986263
11/17/21 11:15 PM
11/17/21 11:15 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I wonder if any of the usual suspects have checked out the "performance" version and verified flow.
Re: What are you using for new Magnum heads these days? [Re: dogdays] #2986266
11/17/21 11:18 PM
11/17/21 11:18 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
People are scrounging for parts right now as you know. Several posts in wanted sections of various boards looking for some used old EQ or RHS castings. I think the guys that were selling the cast iron stuff are now selling prepped sidewinder aluminum castings. As with anything it is more about who builds them in terms of quality.
Re: What are you using for new Magnum heads these days? [Re: Sniper] #2986552
11/18/21 07:52 PM
11/18/21 07:52 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Flow numbers
That is a chinese piece of crap, they no longer make the good ones. The quick easy surefire way to tell the difference is the flat end of the head on the good ones VS these look more like a stock one but they do not flow worth a crap and the casting quality is rougher than a stock one. Pay a local machine shop to do a valve job on your old ones, you'll be better off (ignore the cracks they don't affect anything).
Re: What are you using for new Magnum heads these days? [Re: HotRodDave] #2987172
11/20/21 01:05 PM
11/20/21 01:05 PM
rust belt
Moparite Offline
Moparite  Offline
rust belt
You can get heads from Indy for the magnum, Either la or magnum intake style.
http://www.indyheads.com/images/maxlaxnewproductlinK.pdf
Re: What are you using for new Magnum heads these days? [Re: Moparite] #2987336
11/20/21 11:22 PM
11/20/21 11:22 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
there are no castings available for those heads. if we get lucky, they might have more around the middle of 2022.
