70's bed conversion #2984116
11/11/21 01:25 PM
11/11/21 01:25 PM
Western Colorado High Desert
moparmarks Offline OP
Has anyone changed a long wide box to a short box? 72-80
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 70's bed conversion [Re: moparmarks] #2984157
11/11/21 03:29 PM
11/11/21 03:29 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I believe that would entail a frame rework.
Re: 70's bed conversion [Re: moparmarks] #2984161
11/11/21 03:43 PM
11/11/21 03:43 PM
85086
moparpollack Offline
Lil Herman
Lil Herman
85086
Do you mean cut the long bed down to a short bed? My buddy does chevys all the time I think you could do it with a dodge as well.
Re: 70's bed conversion [Re: stumpy] #2984250
11/11/21 08:04 PM
11/11/21 08:04 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yep, roughly 18" out of the long box frame between the wheel base, to accommodate the short box.
If you don't have a short box to install, you will need to cut about 18" off the front of the 8' bed as well.
You would be ahead of the game to find a short box truck if you really want a short box truck.
Re: 70's bed conversion [Re: poorboy] #2984331
11/11/21 11:25 PM
11/11/21 11:25 PM
Yep I'm talking just the box. Having a hard time finding a real nice short box around here. I have a real nice spare long box so I was thinking....... work
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 70's bed conversion [Re: moparpollack] #2984334
11/11/21 11:28 PM
11/11/21 11:28 PM
Chevy boxes are bolt together where as Dodge boxes are welded together
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 70's bed conversion [Re: moparmarks] #2984479
11/12/21 01:11 PM
11/12/21 01:11 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
There is a difference behind the wheel as well...4" shorter.
Simply need to cut 16" (115 "wb from 131"wb = 16") from the frame rails between the front box mount and the start of the rear axle rise. then section the box similarly. For the rear frame rails (behind the axle) lop the frame off at the forward most bumper hole then remove the next 4” and weld the bumper section back on.Then section the rear of the box 4" from betwene the wheel tub and the rear box mount. More body work than frame work.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 70's bed conversion [Re: W.I.N. Racing] #2985050
11/14/21 10:15 AM
11/14/21 10:15 AM
Well that is a game changer. I've always thought that they were the same on the back end. Guess I'm still looking for a nice short box and now have a nice long box for sale.
Thanks guys for the info.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 70's bed conversion [Re: moparmarks] #2986034
11/17/21 11:18 AM
11/17/21 11:18 AM
central Florida
VL21 Offline
VL21  Offline
central Florida
It would be a long way to come get it, but a friend here has 2 Short beds, one real nice and one with a little rust in the front floor, otherwise good bed.
And he needs the money, his semi just blew up.
It takes gasoline to interest me.
Re: 70's bed conversion [Re: VL21] #2986157
11/17/21 06:10 PM
11/17/21 06:10 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
If moparmarks isnt interested I may be. Live in the Atlanta GA area so not too bad of a drive.
Re: 70's bed conversion [Re: mgoblue9798] #2986949
11/19/21 07:07 PM
11/19/21 07:07 PM
Ya that is a bit far for me, thanks though. I live on the edge of the Southwest Desert so you would think I could find one around here? Nooooooooooo. There are a couple in CA but that is still a bit far.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
