Re: Bigish cam, big motor- BIG redline?
[Re: 8urvette]
#2985619
11/15/21 11:12 PM
11/15/21 11:12 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Give us the lobe duration at .050 lobe lift and the lobe centers, LSA, and were you installed the intake lobes please. Are the Victor heads 440 port size or Max wedge intake port size? how about spring pressures on the seats and open pressures ![work work](/ubbthreads/images/graemlins/custom/work.gif) I'm a firm believer in using the good old butt dyno tach, when the motor quits pulling hard shift it ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Use the butt impression first and then look at the tach. ![scope scope](/ubbthreads/images/graemlins/custom/scope.gif) Which brand and style and center to center length are the rods?
[Re: Cab_Burge]
#2985627
11/15/21 11:28 PM
11/15/21 11:28 PM
Posts: 782 wine country
8urvette
wine country
here is the cam card heads are standard port- springs match cam card
[Re: AndyF]
#2985648
11/16/21 12:43 AM
11/16/21 12:43 AM
8urvette
wine country
People used to use big huge cams like that with old 906 heads but a Victor head shouldn't require that much cam, even in a 540 unless it is a high rpm drag race only application. A bracket car with a trans brake and a 5500 stall converter would work pretty well with that cam but a street car with a four speed is going to be a nightmare. Every time you leave a stop light you'll be slipping the clutch since there will be almost zero torque at anything below 2000 rpm. I am street driving it now. Just got it all together (the car) and am working out the bugs. It isnt bad from a stop actually. Im sure the 4.10s help that out. but cruising under 3k you feel the lope of the cam, LOL! I can just let the clutch out from idle (1100 rpms) and as long as I go slow the car wont stall. But i do agree its bigger than I need. But it is what I have. Just wodnering what RPM MAX this should go to.
[Re: 8urvette]
#2985665
11/16/21 01:59 AM
11/16/21 01:59 AM
Posts: 3,105 Michigan
A727Tflite
Looks a lot like what we used in the 70’s in Super Stock. Smaller in lift than the popular Cam Dynamics R-286 which was .750” at the valve with stock 906 heads. Used the then popular 069J B & M converter which flashed around 4500.
With the stock heads they started to lose power around 6600. Not sure how much better your heads are.
[Re: 8urvette]
#2985695
11/16/21 08:58 AM
11/16/21 08:58 AM
Posts: 714 Lake Villa Il
INTMD8
Lake Villa Il
You could run it on a chassis dyno to figure out ideal shift point.
[Re: B1MAXX]
#2985704
11/16/21 09:41 AM
11/16/21 09:41 AM
Posts: 13,404 Marion, South Carolina [><]
an8sec70cuda
set the shift light to 6600, redline 7200, set the rev limiter to 7500. my ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif) And running a 284 @.050 on the street isn't the end of the world ![realcrazy realcrazy](/ubbthreads/images/graemlins/custom/realcrazy.gif) sounds about right if you want to go fast. As you seem to have found out it will idle and drive. Just keep the right side up. ![iagree iagree](/ubbthreads/images/graemlins/custom/iagree.gif) 5k-7k. Sounds right to me. FWIW...my 575" hemi w/ a 276/284 at .050" cam runs 5000-7200 or so.
[Re: INTMD8]
#2985718
11/16/21 11:03 AM
11/16/21 11:03 AM
8urvette
wine country
You could run it on a chassis dyno to figure out ideal shift point. I will be on the dyno, but I want to get my EFI on first and start dialing in some of that. Also I have a few small things to fix before that too. Small oil leaks here and there.
[Re: merpar]
#2985724
11/16/21 11:31 AM
11/16/21 11:31 AM
Posts: 10,049 MN
JERICOGTX
MN
With a Stock block 4.500 stroke, and stock main caps, I wouldn't be spinning the thing over 6000rpm.
69 GTX
68 Road Runner
[Re: merpar]
#2985744
11/16/21 12:44 PM
11/16/21 12:44 PM
INTMD8
Lake Villa Il
Trust what your car likes not numbers from a dyno. Of course you can experiment at the track but if you have a power curve from a dyno you can calculate ideal shift points and see if you need to make changes in order to keep it in max average horsepower. Altering the engine combination or gearing if need be.
