Bigish cam, big motor- BIG redline? #2985607
11/15/21 10:30 PM
11/15/21 10:30 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I have a 440, ductile iron main caps, block girlde, 440 source stroker kit- 4.5" stroke. 540" motor.
10.5 to 1 compression
cleaned up Victor heads
MSD igniton locked out at 34*
Single plane intake
electric water pump (only pulley turning is the alternator)
TEMPORARY 870 Vaccum secondaries holley (waiting on Holley EFI)
large stepped headers
Cam is a Crane solid roller, .684 lift at rocker with 1.5 rocker, 324* adv duration says minimum rpm 5000, max 8500
Car is a 68 barracuda, 4 speed 18 spline with 4.10 dana 60. tire is a MT ET street 30 x 12.5
What should I spin this motor to? I really am not looking to kick a rod out of the block, but man this thing doesnt come on untill 5k driving it around on the street.
This is a race car that is street driven ( I would go much smaller and more tame if I were do it again)
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985612
11/15/21 10:39 PM
11/15/21 10:39 PM
West Plains, MO
DrCharles Offline
DrCharles  Offline
West Plains, MO
With a 4.5" stroke, you've really got some piston speed there...
Hope you have some good rods (and rod bolts!) scope
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985619
11/15/21 11:12 PM
11/15/21 11:12 PM
Give us the lobe duration at .050 lobe lift and the lobe centers, LSA, and were you installed the intake lobes please.
Are the Victor heads 440 port size or Max wedge intake port size?
how about spring pressures on the seats and open pressures work
I'm a firm believer in using the good old butt dyno tach, when the motor quits pulling hard shift it up scope
Use the butt impression first and then look at the tach. up scope
Which brand and style and center to center length are the rods?
Re: Bigish cam, big motor- BIG redline? [Re: Cab_Burge] #2985627
11/15/21 11:28 PM
11/15/21 11:28 PM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
here is the cam card
heads are standard port- springs match cam card
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985634
11/15/21 11:50 PM
11/15/21 11:50 PM
Windsor, ON, Canada
Diplomat360 Offline
Diplomat360  Offline
Windsor, ON, Canada
Holy crap...284/284 @0.050"!!!
Wow, I honestly thought something hir hairy was "race car only territory" stuff.
Then again, I am sporting a 240/248 in a 408" stroker meant for 95% street use.
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985635
11/15/21 11:53 PM
11/15/21 11:53 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
I you simply take the cam card rpm values and adjust the to the cubic ratio 440/540, the numbers would be 4,000 to 6,700, FWIW
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985636
11/15/21 11:54 PM
11/15/21 11:54 PM
AndyF Offline
AndyF  Offline
Yeah that combination would be almost undriveable on the street with 284 duration at 0.050 and a four speed. The problem with that combination is that the cam doesn't turn on until around 5000 rpm but you can't spin it much past 7000 rpm so you have a very narrow power band. You would probably be a lot happier if the duration was 20 degrees smaller.
Re: Bigish cam, big motor- BIG redline? [Re: AndyF] #2985638
11/15/21 11:57 PM
11/15/21 11:57 PM
AndyF Offline
AndyF  Offline
People used to use big huge cams like that with old 906 heads but a Victor head shouldn't require that much cam, even in a 540 unless it is a high rpm drag race only application. A bracket car with a trans brake and a 5500 stall converter would work pretty well with that cam but a street car with a four speed is going to be a nightmare. Every time you leave a stop light you'll be slipping the clutch since there will be almost zero torque at anything below 2000 rpm.
Re: Bigish cam, big motor- BIG redline? [Re: AndyF] #2985648
11/16/21 12:43 AM
11/16/21 12:43 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I am street driving it now. Just got it all together (the car) and am working out the bugs. It isnt bad from a stop actually. Im sure the 4.10s help that out. but cruising under 3k you feel the lope of the cam, LOL! I can just let the clutch out from idle (1100 rpms) and as long as I go slow the car wont stall. But i do agree its bigger than I need. But it is what I have.
Just wodnering what RPM MAX this should go to.
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985665
11/16/21 01:59 AM
11/16/21 01:59 AM
A727Tflite Online content
A727Tflite  Online Content
Looks a lot like what we used in the 70’s in Super Stock.
Smaller in lift than the popular Cam Dynamics R-286 which was .750” at the valve with stock 906 heads. Used the then popular 069J B & M converter which flashed around 4500.
With the stock heads they started to lose power around 6600. Not sure how much better your heads are.
Re: Bigish cam, big motor- BIG redline? [Re: A727Tflite] #2985691
11/16/21 08:39 AM
11/16/21 08:39 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
set the shift light to 6600, redline 7200, set the rev limiter to 7500. my twocents And running a 284 @.050 on the street isn't the end of the world realcrazy sounds about right if you want to go fast. As you seem to have found out it will idle and drive. Just keep the right side up. drive
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985695
11/16/21 08:58 AM
11/16/21 08:58 AM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
You could run it on a chassis dyno to figure out ideal shift point.
Re: Bigish cam, big motor- BIG redline? [Re: B1MAXX] #2985704
11/16/21 09:41 AM
11/16/21 09:41 AM
an8sec70cuda Offline
iagree 5k-7k. Sounds right to me.
FWIW...my 575" hemi w/ a 276/284 at .050" cam runs 5000-7200 or so.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Bigish cam, big motor- BIG redline? [Re: INTMD8] #2985718
11/16/21 11:03 AM
11/16/21 11:03 AM
wine country
8
8urvette Offline OP
8urvette  Offline OP
wine country
I will be on the dyno, but I want to get my EFI on first and start dialing in some of that. Also I have a few small things to fix before that too. Small oil leaks here and there.
Re: Bigish cam, big motor- BIG redline? [Re: INTMD8] #2985722
11/16/21 11:28 AM
11/16/21 11:28 AM
Nevada
merpar Offline
merpar  Offline
Nevada
I agree with CAB, butt dyno and et slip. It shouldn't take more than 4 or 5 passes to find your sweet spot. I would start your shift rpm at about 6500 and keep moving it up until you get your best et and speed. Trust what your car likes not numbers from a dyno.
Re: Bigish cam, big motor- BIG redline? [Re: merpar] #2985724
11/16/21 11:31 AM
11/16/21 11:31 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
With a Stock block 4.500 stroke, and stock main caps, I wouldn't be spinning the thing over 6000rpm.
69 GTX 68 Road Runner
Re: Bigish cam, big motor- BIG redline? [Re: JERICOGTX] #2985727
11/16/21 11:36 AM
11/16/21 11:36 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
7000
Re: Bigish cam, big motor- BIG redline? [Re: merpar] #2985744
11/16/21 12:44 PM
11/16/21 12:44 PM
Lake Villa Il
INTMD8 Offline
INTMD8  Offline
Lake Villa Il
Of course you can experiment at the track but if you have a power curve from a dyno you can calculate ideal shift points and see if you need to make changes in order to keep it in max average horsepower. Altering the engine combination or gearing if need be.
Re: Bigish cam, big motor- BIG redline? [Re: 8urvette] #2985747
11/16/21 12:54 PM
11/16/21 12:54 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Why bother
Boffin Emeritus
Re: Bigish cam, big motor- BIG redline? [Re: polyspheric] #2985768
11/16/21 02:07 PM
11/16/21 02:07 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I run a 285@.050" cam in my racecar. 572" it likes 6900. My bet is yours will want more.
Doug
