Re: Break in oils
[Re: Cab_Burge]
#2981654
11/04/21 01:38 PM
11/04/21 01:38 PM
Posts: 19,382 Las Vegas
Al_Alguire
Las Vegas
I have had good luck with Driven and Penn Grade break in oils
Re: Break in oils
[Re: Al_Alguire]
#2981657
11/04/21 01:49 PM
11/04/21 01:49 PM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
I've used Driven break in oil and also used Valvoline VR-1 w/ Comp Cams break-in additive successfully. Both were 440 Mopars. That's the only two flat tappet motors I've built in the last 10 years.
Re: Break in oils
[Re: DusterKid]
#2981661
11/04/21 02:00 PM
11/04/21 02:00 PM
Posts: 5,444 Indiana
YO7_A66
Indiana
My last cam was broke in over the past Spring with the Driven break in oil with no problems.
1970 YO7 A66 [Canadian Export] F8 Challenger 340 (Currently in shop for stroker assy.)
Re: Break in oils
[Re: DusterKid]
#2981681
11/04/21 02:25 PM
11/04/21 02:25 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I picked Driven for breakin. There is a possibility of having a problem when using additives and some oils. As I recall a certain level of friction needs to be present for best ring seal results. That must be balanced with requirements for successful flat tappet cam breakin. So I stick with good breakin oil and no additives to avoid possible issues.
Re: Break in oils
[Re: cl440]
#2981926
11/05/21 08:24 AM
11/05/21 08:24 AM
Posts: 4,457 Washington
madscientist
Washington
Driven and Torco. I prefer the Torco but it’s more expensive.
Re: Break in oils
[Re: DusterKid]
#2981972
11/05/21 10:19 AM
11/05/21 10:19 AM
Posts: 17,907 S.E. Michigan
ZIPPY
S.E. Michigan
Last FT 440 was around 2013, I used Chevron Delo400 SAE 30, with a pint of CD2 street legal oil boost additive.
The CD2 additive is no longer readily available but has good numbers in analysis. I bought a bunch of it on closeout. Zinc: 4898 ppm (4700) Phosphorus: 4921 ppm (4300) Calcium: 4279 ppm (7800) Moly: 0 ppm (0) Vis @100C: 29.5 cSt (28)
Rich H.
Esse Quam Videri
Re: Break in oils
[Re: ZIPPY]
#2982557
11/06/21 09:52 PM
11/06/21 09:52 PM
Posts: 71 Fort Walton Beach
mothermopar
Fort Walton Beach
Brad Penn oil is what I've used and never had a issue.
1969 Superbee, Hemi, 4 Spd, Supertrack Pack 2007 Dodge Ram 2500, 4x4, 5.9 Cummins
Re: Break in oils
[Re: DusterKid]
#2982631
11/07/21 09:04 AM
11/07/21 09:04 AM
Posts: 4,210 New York
polyspheric
New York
If you insist on single weight (non-"W") get it as warm as possible first.
Boffin Emeritus
Re: Break in oils
[Re: polyspheric]
#2982673
11/07/21 10:52 AM
11/07/21 10:52 AM
Posts: 3,245 Md.
carnut68
Md.
Are you guys breaking in your cams in with the springs as installed or are you removing the inner springs?
America First!
