Break in oils #2981615
11/04/21 12:06 PM
11/04/21 12:06 PM
Keymar, MD
DusterKid Offline OP
Keymar, MD
What brand of break in oils have you used successfully to break in a flat tappet cam? Which brands have you had failures with?
Re: Break in oils [Re: DusterKid] #2981617
11/04/21 12:12 PM
11/04/21 12:12 PM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I have used succesfully:
brad penn break-in
or
the comp break-in additive with VR1
Re: Break in oils [Re: B1MAXX] #2981619
11/04/21 12:17 PM
11/04/21 12:17 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Gibbs' Driven and Lucas have worked for me.
VR1 is also FT-friendly.
Re: Break in oils [Re: DusterKid] #2981650
11/04/21 01:34 PM
11/04/21 01:34 PM
Regular 10x30Wt. Valvoline with a bottle of Lucas zinc plus additive up scope
Re: Break in oils [Re: Cab_Burge] #2981654
11/04/21 01:38 PM
11/04/21 01:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I have had good luck with Driven and Penn Grade break in oils
Re: Break in oils [Re: Al_Alguire] #2981657
11/04/21 01:49 PM
11/04/21 01:49 PM
an8sec70cuda Offline
I've used Driven break in oil and also used Valvoline VR-1 w/ Comp Cams break-in additive successfully. Both were 440 Mopars.
That's the only two flat tappet motors I've built in the last 10 years.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Break in oils [Re: DusterKid] #2981661
11/04/21 02:00 PM
11/04/21 02:00 PM
Indiana
Y
YO7_A66 Offline
YO7_A66  Offline
Y
Indiana
My last cam was broke in over the past Spring with the Driven break in oil with no problems.
Re: Break in oils [Re: DusterKid] #2981681
11/04/21 02:25 PM
11/04/21 02:25 PM
gregsdart Offline
gregsdart  Offline
I picked Driven for breakin. There is a possibility of having a problem when using additives and some oils. As I recall a certain level of friction needs to be present for best ring seal results. That must be balanced with requirements for successful flat tappet cam breakin.
So I stick with good breakin oil and no additives to avoid possible issues.
Re: Break in oils [Re: gregsdart] #2981683
11/04/21 02:41 PM
11/04/21 02:41 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
Lucas 30wt break in oil on the most recent build (June 2021)
Re: Break in oils [Re: cl440] #2981926
11/05/21 08:24 AM
11/05/21 08:24 AM
Washington
madscientist Offline
Washington
Driven and Torco. I prefer the Torco but it’s more expensive.
Re: Break in oils [Re: madscientist] #2981958
11/05/21 10:02 AM
11/05/21 10:02 AM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
10W30 Valvoline VR1, same as my regular oil.
This with supplied cam lube from Ma Mopar.
Six years and going with no discernable wear.
Of course, your viscosity may vary....
Joe
Re: Break in oils [Re: DusterKid] #2981972
11/05/21 10:19 AM
11/05/21 10:19 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Last FT 440 was around 2013, I used Chevron Delo400 SAE 30, with a pint of CD2 street legal oil boost additive.
The CD2 additive is no longer readily available but has good numbers in analysis. I bought a bunch of it on closeout.
Zinc: 4898 ppm (4700) Phosphorus: 4921 ppm (4300) Calcium: 4279 ppm (7800) Moly: 0 ppm (0) Vis @100C: 29.5 cSt (28)
Rich H.
Esse Quam Videri
Re: Break in oils [Re: ZIPPY] #2982557
11/06/21 09:52 PM
11/06/21 09:52 PM
Fort Walton Beach
mothermopar Offline
mothermopar  Offline
Fort Walton Beach
Brad Penn oil is what I've used and never had a issue.
1969 Superbee, Hemi, 4 Spd, Supertrack Pack
2007 Dodge Ram 2500, 4x4, 5.9 Cummins
Re: Break in oils [Re: mothermopar] #2982561
11/06/21 10:11 PM
11/06/21 10:11 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Last one I did I used GM EOS and poured it in with regular Valvoline 10w-40.
Re: Break in oils [Re: DusterKid] #2982631
11/07/21 09:04 AM
11/07/21 09:04 AM
New York
polyspheric Offline
polyspheric  Offline
New York
If you insist on single weight (non-"W") get it as warm as possible first.
Boffin Emeritus
Re: Break in oils [Re: polyspheric] #2982673
11/07/21 10:52 AM
11/07/21 10:52 AM
Md.
carnut68 Offline
carnut68  Offline
Md.
Are you guys breaking in your cams in with the springs as installed or are you removing the inner springs?
America First!
Re: Break in oils [Re: carnut68] #2982687
11/07/21 11:30 AM
11/07/21 11:30 AM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I remove inner springs. Also, I always spin the engine over to make sure ft lifters are turning.
