Garage creepers?
#2981153
11/02/21 11:38 PM
11/02/21 11:38 PM
Posts: 4,720 Moved to N.E. Tennessee
GomangoCuda
The one I have been using for almost 50 years broke a wheel. I know there have been a few different designs come out over the years. What are you using and would you recommend it? Thanks. might be an early Christmas present to myself.
Re: Garage creepers?
[Re: GomangoCuda]
#2981204
11/03/21 08:36 AM
11/03/21 08:36 AM
Posts: 4,977 new jersey usa
11secdart
new jersey usa
I have had several different ones over the years I always seem to have problems with them as the wheels are always coming loose and falling off. I think is just the way that the wheels are attached as they always come loose. I don't even use them a lot but it seems to be an ongoing problem with every brand I purchase.
[Re: 11secdart]
#2981207
11/03/21 08:55 AM
11/03/21 08:55 AM
Posts: 13,363 Marion, South Carolina [><]
an8sec70cuda
I've had the same problem. Last one I got came from NAPA. OK for a while, then one of the wheels came apart. That was a few years ago. I think I'm going to get some replacement casters from AgriSupply and see if they'll work on it.
[Re: an8sec70cuda]
#2981229
11/03/21 09:49 AM
11/03/21 09:49 AM
Posts: 4,566 Motor City
6PKRTSE
Motor City
I have had one of those big ole dog done shaped creepers for over 25+ years. So far it is indestructible. Still has original wheels. Good thing about the wheels. They are like 5" in dia and roll right over cracks easily.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: 65pacecar]
#2981367
11/03/21 02:16 PM
11/03/21 02:16 PM
Posts: 19,399 north of coder
moparx
the only real drawback to cardboard creepers, they are hard to "store". but when they get dirty, they can be flipped over and used some more. i have seen those "magic creepers" advertised, and they look pretty appealing to me. however, i have a lifetime supply [or a supply that will last as long as i do ] of cardboard, so i'll just use that up.
[Re: 65pacecar]
#2981368
11/03/21 02:18 PM
11/03/21 02:18 PM
6PKRTSE
Motor City
I also use the blue foam sheets as pictured that I get from my buddy who works at a paint and body shop that all of their new body panels come wrapped in. It is water proof, liquid wipe right off, it's padded about 1/2" thick, doesn't catch on fire when welding and is slippery. You can just slide in and out right under the car.
[Re: 6PKRTSE]
#2981374
11/03/21 02:27 PM
11/03/21 02:27 PM
Posts: 30,424 Florida STAYcation
dOrk !
The village idiot's idiot
Florida STAYcation
A chunk o carpet here But the flipped over cardboard ? ... on a garage DIRT FLOOR! Sounds like a CREEPY WAY of doing it
[Re: GomangoCuda]
#2981376
11/03/21 02:30 PM
11/03/21 02:30 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I really like the one I got at Tractor Supply. I see they jumped up in price (55.00 now). I know I paid under 35.00 Years ago. Maybe find it somewhere cheaper or during Black Friday sales.
[Re: pittsburghracer]
#2981400
11/03/21 04:12 PM
11/03/21 04:12 PM
GomangoCuda
Same thing at Summit is $35. 250# weight limit. I might be a little heavier than that. Harbour freight is also $35 and 300# limit. Summit's worthless warranty starts with "Summit Racing Equipment® warrants this product for one year from the date of purchase. If the product is used for racing or competition, this warranty is limited to manufacturer defects only; wear and breakage are not covered under any circumstances". Does anybody race creepers? Are there SFI spec creepers? Do they have to be replaced every 2 years. Who sells 3/4 race wheels for them?
[Re: GomangoCuda]
#2981406
11/03/21 04:32 PM
11/03/21 04:32 PM
GomangoCuda
Like most here I have used cardboard as a low clearance creeper since before I had a real creeper. Probably why my creeper has lasted as long as it has. I have a life time supply of cardboard now. The previous owner of this house shipped dulcimers all over the world. There are stacks of unused boxes in my attic. I still want to replace my creeper as it's always easier for an old fat guy to roll than wiggle around on cardboard.
[Re: 6PKRTSE]
#2981434
11/03/21 06:25 PM
11/03/21 06:25 PM
Posts: 4,920 new berlin wisconsin
Mr T2U
I also use the blue foam sheets as pictured that I get from my buddy who works at a paint and body shop that all of their new body panels come wrapped in. It is water proof, liquid wipe right off, it's padded about 1/2" thick, doesn't catch on fire when welding and is slippery. You can just slide in and out right under the car. the blue foam usually covers Ford bumpers. the smooth side is only on one side. VW uses similar stuff to wrap bumpers but puts the smooth part on both sides of the foam. lately VW has been using a different cheaper grade of foam. they also have started to wrap bumpers in special paper with 5 layers instead of foam on some bumpers. so i don't have access to as much foam as i used to get. the nice part of the foam is it also has insulating properties when laying on cold concrete. this also makes excellent packing material when shipping. in the past i used to use rigid Styrofoam they use to put on the outside of houses. this can get $$$ if you have to buy it.
perception is 90% of reality
[Re: Mr T2U]
#2981448
11/03/21 07:00 PM
11/03/21 07:00 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
We should all go on a diet. Our bodies a d creepers would last longer. That’s it I’m doing it. I’m going to start next week. 😂
#2981462
11/03/21 07:24 PM
11/03/21 07:24 PM
Posts: 10,558 Freeport IL USA
poorboy
Freeport IL USA
Garage creepers are disposable items. Until the last scrap run, I had 3 or 4 creeper frames with missing and/or broken wheels, and broken plywood. The hard plastic ones crack and drag on the floor until the wheels break. None of then are any good.
When I started swapping out the wheels from one frame to another, I got another year (maybe) out of the repaired creeper.
A few years ago I stumbled across a couple plastic chairs that came with caster wheels, I cut them off the chair and welded them to the creeper frames. They have actually worked pretty well, as long as the floor doesn't have cracks, or cords laying on them you roll over with the creeper. Unfortunately, those chair casters raised up the creeper off the floor another inch, and I only had 8 casters. When these casters are gone, or this last creeper frame breaks, I'm going the cardboard creeper process. My days working under stuff is rapidly coming to an end anyway. Gene
