Re: Good/cheap OBD scanner??
[Re: MI_Custumz]
#2980787
11/02/21 07:39 AM
11/02/21 07:39 AM
Posts: 1,663 South Lyon, MI.48178
kwhmopar1
Basically any cheap scanner/reader will do what you are looking for. Read and erase codes. https://smile.amazon.com/Autel-MaxiScan-MS300-Diagnostic-Vehicles/dp/B001LHVOVK/ref=sr_1_14?crid=2H1LGS6801NIA&dchild=1&keywords=obdii+code+reader&qid=1635852742&qsid=137-2048843-9344431&smid=A1KK3CLSXM5E1F&sprefix=OBDII%2Caps%2C112&sr=8-14&sres=B01G5EA74I%2CB00UJV3E12%2CB07Z3HB7DR%2CB007XE8C74%2CB00652G4TS%2CB07Q5H7M5S%2CB08MKXLS51%2CB001LHVOVK%2CB07M8B7TXD%2CB07Z481NJM%2CB0887WYZVH%2CB013RIQMEO%2CB005NLQAHS%2CB071FSNL73%2CB08F5DDLNX%2CB07WT82MT4%2CB07Z46L5FG%2CB07Q2L41VJ%2CB08PFJMTY3%2CB07D1KH9SC&srpt=VEHICLE_SCAN_TOOL This one says it works with iPhone. https://www.fixd.com/sensor-67?gcli...hL4ZxHS2WFVWMGrn2-VHh5eqpRsaAgumEALw_wcB
Junk is something you throw away just before you need it.
[Re: MI_Custumz]
#2980791
11/02/21 08:06 AM
11/02/21 08:06 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
As I have already posted here, I saw eight Konnwei KW681 OBD-II scanners in a Goodwill Store priced at $7.99 each. These were still in shrink wrapped boxes. The box said they were also 12 volt lead acid battery testers.
I decided to risk buying one. I had never heard of Konnwei.
The battery testing involved many different USA, Euro, DIN, Japanese, and China test procedures. They all seem to be able to rate new good batteries, from older still good batteries, to a bad battery with one shorted cell with sulphation.
The OBD-II could detect DTC, erase DTCs, and show “pending” Mode$07 DTCs yet to turn on the dash trouble light.
Sensor outputs could all be displayed and auto-updated every few seconds.
There is an oxygen sensor pass/fail test. There is an alternator ripple voltage test.
It showed me a general P0700 transmission code, and a P0755 sub code..
It tells me there are two PCMs, and I am guessing the second PCM is the transmission computer.
I tried, but could not find out how to read CVI, or “Clutch Volume Index”. It may be possible, but the instruction book is not well written. The Chinese section of the book seems much longer, and when my fluent Chinese speaking niece next visits I am going to ask her if there is more info.
There is a micro USB port for updates.
Well worth $8, and I wish I had bought a couple more.
Konnwei makes more than a dozen different models, says the advertising flyer with pictures in the box.
[Re: MI_Custumz]
#2980993
11/02/21 06:35 PM
11/02/21 06:35 PM
Posts: 12,074 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
We have been using the Autel scanners the last few years. They have a large selection of scanners from basic ones to all inclusive ones. They are available from Amazon and on Ebay. Close-out models come along pretty often, too. Good bang for the buck.
Master, again and still
[Re: MI_Custumz]
#2981235
11/03/21 10:01 AM
11/03/21 10:01 AM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
AutoZone and O'Reilly's (and others) will pull your codes for free. Seven days a week. They won't clear the codes, but they will let you push the button to do it.
[Re: DaveRS23]
#2981249
11/03/21 10:24 AM
11/03/21 10:24 AM
Posts: 5,948 British Columbia
chrisf
British Columbia
i have been super happy with my blue driver scanner. its iphone/android based and connects via bluetooth. it does a ton of stuff including live data. i am totally impressed with how well it works especially for the price. its on amazon for $119. when you scan a error code it even has the most common fixes associated with that code i have two of them and going to buy a few more just to leave in the glove box of my vehicles) https://us.bluedriver.com/pages/bluedriver
