71 Cuda Wheels #2980623
11/01/21 05:06 PM
11/01/21 05:06 PM
Houston, TX
sbklf Offline OP
sbklf  Offline OP
Houston, TX
Which Rallye wheels and what size would have most likely come on my 71 Cuda?
It has what looks like the Magnum 500's on it but not sure because it seems the outer shell (?) of the rim is painted with beauty rings. Probably use to know this but it has been a while since I worked on the car. I did 90% of the restoration myself but I have not worked on it much since then which is about 15 years now. I do know that I want Rallye rims, any advise on this would be appreciated including what is the best way to get a set (new from Wheel Vintiques, trade...)? I would want 5.
Thanks, Kevin
Re: 71 Cuda Wheels [Re: sbklf] #2980691
11/01/21 07:42 PM
11/01/21 07:42 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
'69-up Mopar Magnums used trim rings over black barrels.
Broadcast Sheet will specify which wheels it was born with.
Re: 71 Cuda Wheels [Re: topside] #2980779
11/02/21 05:51 AM
11/02/21 05:51 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the most common wheel & tire combination for a '71 'cuda was: W21 & T87
14x5.5" Rallye wheels w/trim rings & F70-14 Goodyear Polyglas w/Raised White Letter tires
here's the breakdown for US spec'd '71 'cudas hardtops & convertibles combined (86% of the years' production)
Re: 71 Cuda Wheels [Re: 6bblgt] #2980780
11/02/21 06:07 AM
11/02/21 06:07 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
here's the rarest combination W12 & U84 on a hemi'cuda grin
Re: 71 Cuda Wheels [Re: 6bblgt] #2980804
11/02/21 08:51 AM
11/02/21 08:51 AM
Houston, TX
sbklf Offline OP
sbklf  Offline OP
Houston, TX
Great, thanks. I will pull out the build sheet.
Did not know there were so many options, are Road Wheels similar to Magnum 500's?
If it came with these wheels I might leave it alone, I will try to post a picture.
Re: 71 Cuda Wheels [Re: sbklf] #2980964
11/02/21 04:10 PM
11/02/21 04:10 PM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
Road wheels had a black painted hoop with trim rings. Magnum 500's looked the same
except that the hoop was chrome, so no need for a trim ring.
