Page 1 of 3 1 2 3
Nostalgia Pro Stock - Super Stock Springs #2979843
10/30/21 11:11 AM
10/30/21 11:11 AM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Hey everybody,
I'm just curious if anybody is currently still using a Super Stock spring / Pinion snubber combo and fast they are going. ET ? MPH ? 60' ? I would also like to know if anybody is currently using a "Rear" anti roll bar with Super stock springs?
Building a 72 Pro Stock Cuda. I have it in my mind that it will most likely get switched to a Caltrack system, split mono leaf and a slider in the end but I would really like to just try the S/S springs and see what we can do smile It also allows me to build the car and then custom tailor the Caltrack system to the car. Ride height, spring Length’s etc. But.... if the S/S springs work, they might just stay put! Who knows smile
This car WILL be active, not so much as a "every" weekend racer but will attend and race a few Nostalgia events per year.
Facts to consider.... E-body, approx. 2800lbs, 800 to 1000 HP, 31x10.5w tire, Auto (for now but has clutch peddle smile ), Dana, 4.10 gear
Anybody have any personal experience with this type of combo here?
Thanks for reading smile
Re: Nostalgia Pro Stock - Super Stock Springs [Re: WH23H6] #2979922
10/30/21 02:48 PM
10/30/21 02:48 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Cal-tracs are smoother, more consistent and have better longevity than the current MP SS springs.
'63 Dodge 330
11.19 @ 121 mph
Re: Nostalgia Pro Stock - Super Stock Springs [Re: WH23H6] #2979927
10/30/21 02:56 PM
10/30/21 02:56 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
Back in the early 90s......
69' Barracuda, SS springs with the cheap shocks they were usually paired with and nothing else as far as snubbers, bars, etc. 3280#, Mark Williams Dana 60, with 4.56s, stock ratio 727 with 8" converter that was foot braked to about 2000rpm and flashed to around 5000rpm. Nothing special 499ci wedge, with Indy 440-1s. 9.20s to 9.40s depending on weather conditions at ATCO, with a best 60' of 1.28. Street driven as if gas was free..........and although we're still dummies, we were much dumber back then.
PS.......inboard kit w/ 12" Firestones on 15 x 12 Centerlines.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: GY3] #2979930
10/30/21 03:07 PM
10/30/21 03:07 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
If Cal-tracs are an option I wouldn't waste the time or money on S/S springs and pinion snubber.
The whole idea with S/S springs is the front segment has virtually no flex - all that is left to the rear segment. So basically you now have a solid front lower link. The snubber acts as the upper link.. Tuning is limited to moving the front mount up or down and/or the pinion snubber gap.
Cal-tracs work in a similar manner - the front mono segment has a bit of flex. The lower bars are lengthened or shortened to affect the flex and subsequent "hit". But the advantage is that both sides are adjustable.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: Stanton] #2979991
10/30/21 05:59 PM
10/30/21 05:59 PM
Washington
madscientist Offline
Washington
Before I bought Cal-Tracks I would spend the same money and buy the Assassin bars from Smith Race craft in Texas. Far more adjustable.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: madscientist] #2980075
10/30/21 10:37 PM
10/30/21 10:37 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That just means you'll be saying "sh!t, that didn't work" more often.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: madscientist] #2980192
10/31/21 11:37 AM
10/31/21 11:37 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I don't know what type support is provided for the Assassin Bars but I would be hard to imagine them doing any better than Calvert.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: madscientist] #2980200
10/31/21 11:44 AM
10/31/21 11:44 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
The Rube Goldberg of traction aids.
99% of the fastest leaf spring cars are using Cal-tacs.
'63 Dodge 330
11.19 @ 121 mph
Re: Nostalgia Pro Stock - Super Stock Springs [Re: GY3] #2980208
10/31/21 12:03 PM
10/31/21 12:03 PM
Washington
Washington
Adjustability is bad? Got it. Learn to tune and they work. Any dedicated race car that isn’t rule limited to leaf springs should run the Rube Goldberg inspired 4 link.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: madscientist] #2980218
10/31/21 12:49 PM
10/31/21 12:49 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
More adjustability does not necessarily equate to better performance. I have many slots on the crank gear of my timing set. It doesn't mean the other slots provide any value to my combination.
'63 Dodge 330
11.19 @ 121 mph
Re: Nostalgia Pro Stock - Super Stock Springs [Re: GY3] #2980251
10/31/21 02:09 PM
10/31/21 02:09 PM
Sticky South
Rodenteliminator Online content
Rodenteliminator  Online Content
Sticky South
How do know ? Once you find what works you don’t change it but how did you get there ?
Sorry honey I spent the rent
Re: Nostalgia Pro Stock - Super Stock Springs [Re: WH23H6] #2980255
10/31/21 02:44 PM
10/31/21 02:44 PM
New York
polyspheric Offline
polyspheric  Offline
New York
Against SS:
designed for a heavier car with smaller tires and far less power
the left-right spring bias is not what your car wants, and difficult to modify
Boffin Emeritus
Re: Nostalgia Pro Stock - Super Stock Springs [Re: polyspheric] #2980395
10/31/21 10:00 PM
10/31/21 10:00 PM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Originally Posted by polyspheric
Against SS:
penguin This. Power to weight ratio is way different than a 60's Super Stocker. Caltracs and monoleafs (not SS springs) can work but are only optimal for classes that only allow bolt on suspension mods.
Your going to want a 4 link or at least ladder bars.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: WH23H6] #2980410
10/31/21 10:58 PM
10/31/21 10:58 PM
If I was you I would put that money towards a set of ladder bars and coil overs shock conversion, that frees up a bunch of clearances for bigger tires later up scope
My old pump gas street car with that set up would hooked up in a mud puddle during a rain storm boogie whistling
A.K.A. it would hook really well on the street and at the tracks, best 60 ft. was around 1.37 boogie That pushes you way back in the seat at the hit, it will even hurt your neck and back until you get use to it leaving that hard up scope
Re: Nostalgia Pro Stock - Super Stock Springs [Re: Cab_Burge] #2980417
10/31/21 11:14 PM
10/31/21 11:14 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
My pump gas with mufflers street car with Cal-Tracs and 275's has done 1.36, so.... shruggy
'63 Dodge 330
11.19 @ 121 mph
Re: Nostalgia Pro Stock - Super Stock Springs [Re: GY3] #2980527
11/01/21 11:58 AM
11/01/21 11:58 AM
Apollo, PA.
B1MAXX Online content
B1MAXX  Online Content
Apollo, PA.
I've been 1.34-1.37 with 002/003 and a snubber., best ever 1.31 all steel/stock glass 71 Dart with a good rb stroker. I wouldn't consider the 60's it's strong point though. It was inconsistent, and when wheelie-ing would go right. But it is cheap. It would body lift the left rear a good bit but hardly anything on the right rear. Which is why I think it went right by shortening /pulling the left rear forward.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: B1MAXX] #2980545
11/01/21 12:47 PM
11/01/21 12:47 PM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Hey , Thanks for responding.
Did you have a Rear Anti Roll bar on the car? Just curious. smile Also.. How stable "stable" was the car at the big end?
Chris
Re: Nostalgia Pro Stock - Super Stock Springs [Re: B1MAXX] #2980551
11/01/21 12:56 PM
11/01/21 12:56 PM
Closest Race Track
W
WH23H6 Offline OP
WH23H6  Offline OP
W
Closest Race Track
Also... you mind me asking where you got that scoop? And how tall it is? smile Same one I am currently looking for ... I think... lol
Re: Nostalgia Pro Stock - Super Stock Springs [Re: WH23H6] #2980628
11/01/21 05:26 PM
11/01/21 05:26 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
I need one of the "Mopar Pro Stock Hoods" too for my nostalgia dart build. When I was seeing if they were around, I believe speedway motors had them. An ebay search may get you started as to who actually has them too.
Re: Nostalgia Pro Stock - Super Stock Springs [Re: BigBlockGTS] #2980730
11/01/21 09:42 PM
11/01/21 09:42 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I went 1.34 and 9.80’s in a 3350 pound A body Duster. Not minitubbed, 28 by 10 tire, with cheap CE 3 way shocks all around, 002/003 super stock springs, no pinion snubber.
Car was ultra consistent, would hook on ice.
That said, i consider an E body a harder car to get to work because of no rear overhang like A and B bodies have. Significant liability.
Were it me, making 800-1000 horsepower, and not looking to set world speed records, but trying to have a reliable car, i would move right past Calverts and go with ladder bars, or 4 link.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Page 1 of 3 1 2 3
