Nostalgia Pro Stock - Super Stock Springs
#2979843
10/30/21 11:11 AM
10/30/21 11:11 AM
Posts: 134 Closest Race Track
WH23H6
Closest Race Track
Hey everybody, I'm just curious if anybody is currently still using a Super Stock spring / Pinion snubber combo and fast they are going. ET ? MPH ? 60' ? I would also like to know if anybody is currently using a "Rear" anti roll bar with Super stock springs? Building a 72 Pro Stock Cuda. I have it in my mind that it will most likely get switched to a Caltrack system, split mono leaf and a slider in the end but I would really like to just try the S/S springs and see what we can do It also allows me to build the car and then custom tailor the Caltrack system to the car. Ride height, spring Length’s etc. But.... if the S/S springs work, they might just stay put! Who knows This car WILL be active, not so much as a "every" weekend racer but will attend and race a few Nostalgia events per year. Facts to consider.... E-body, approx. 2800lbs, 800 to 1000 HP, 31x10.5w tire, Auto (for now but has clutch peddle ), Dana, 4.10 gear Anybody have any personal experience with this type of combo here? Thanks for reading
Re: Nostalgia Pro Stock - Super Stock Springs
[Re: WH23H6]
#2979922
10/30/21 02:48 PM
10/30/21 02:48 PM
Posts: 4,693 Wichita
GY3
Wichita
Cal-tracs are smoother, more consistent and have better longevity than the current MP SS springs.
[Re: WH23H6]
#2979927
10/30/21 02:56 PM
10/30/21 02:56 PM
Posts: 2,028 Trumbull,CT.
jim sciortino
Trumbull,CT.
Back in the early 90s......
69' Barracuda, SS springs with the cheap shocks they were usually paired with and nothing else as far as snubbers, bars, etc. 3280#, Mark Williams Dana 60, with 4.56s, stock ratio 727 with 8" converter that was foot braked to about 2000rpm and flashed to around 5000rpm. Nothing special 499ci wedge, with Indy 440-1s. 9.20s to 9.40s depending on weather conditions at ATCO, with a best 60' of 1.28. Street driven as if gas was free..........and although we're still dummies, we were much dumber back then.
PS.......inboard kit w/ 12" Firestones on 15 x 12 Centerlines.
[Re: Stanton]
#2979991
10/30/21 05:59 PM
10/30/21 05:59 PM
Posts: 4,457 Washington
madscientist
Washington
Before I bought Cal-Tracks I would spend the same money and buy the Assassin bars from Smith Race craft in Texas. Far more adjustable.
[Re: madscientist]
#2980192
10/31/21 11:37 AM
10/31/21 11:37 AM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Before I bought Cal-Tracks I would spend the same money and buy the Assassin bars from Smith Race craft in Texas. Far more adjustable. I don't know what type support is provided for the Assassin Bars but I would be hard to imagine them doing any better than Calvert.
[Re: madscientist]
#2980200
10/31/21 11:44 AM
10/31/21 11:44 AM
GY3
Wichita
Before I bought Cal-Tracks I would spend the same money and buy the Assassin bars from Smith Race craft in Texas. Far more adjustable. The Rube Goldberg of traction aids. 99% of the fastest leaf spring cars are using Cal-tacs.
[Re: GY3]
#2980208
10/31/21 12:03 PM
10/31/21 12:03 PM
madscientist
Washington
Before I bought Cal-Tracks I would spend the same money and buy the Assassin bars from Smith Race craft in Texas. Far more adjustable. The Rube Goldberg of traction aids. 99% of the fastest leaf spring cars are using Cal-tacs. Adjustability is bad? Got it. Learn to tune and they work. Any dedicated race car that isn’t rule limited to leaf springs should run the Rube Goldberg inspired 4 link.
[Re: madscientist]
#2980218
10/31/21 12:49 PM
10/31/21 12:49 PM
GY3
Wichita
Before I bought Cal-Tracks I would spend the same money and buy the Assassin bars from Smith Race craft in Texas. Far more adjustable. The Rube Goldberg of traction aids. 99% of the fastest leaf spring cars are using Cal-tacs. Adjustability is bad? Got it. Learn to tune and they work. Any dedicated race car that isn’t rule limited to leaf springs should run the Rube Goldberg inspired 4 link. More adjustability does not necessarily equate to better performance. I have many slots on the crank gear of my timing set. It doesn't mean the other slots provide any value to my combination.
[Re: GY3]
#2980251
10/31/21 02:09 PM
10/31/21 02:09 PM
Posts: 170 Sticky South
Rodenteliminator
Sticky South
How do know ? Once you find what works you don’t change it but how did you get there ?
Sorry honey I spent the rent
[Re: WH23H6]
#2980255
10/31/21 02:44 PM
10/31/21 02:44 PM
Posts: 4,209 New York
polyspheric
New York
Against SS: designed for a heavier car with smaller tires and far less power the left-right spring bias is not what your car wants, and difficult to modify
Boffin Emeritus
[Re: polyspheric]
#2980395
10/31/21 10:00 PM
10/31/21 10:00 PM
Posts: 4,735 Moved to N.E. Tennessee
GomangoCuda
Against SS: designed for a heavier car with smaller tires and far less power the left-right spring bias is not what your car wants, and difficult to modify This. Power to weight ratio is way different than a 60's Super Stocker. Caltracs and monoleafs (not SS springs) can work but are only optimal for classes that only allow bolt on suspension mods. Your going to want a 4 link or at least ladder bars.
[Re: Cab_Burge]
#2980417
10/31/21 11:14 PM
10/31/21 11:14 PM
GY3
Wichita
My pump gas with mufflers street car with Cal-Tracs and 275's has done 1.36, so....
[Re: B1MAXX]
#2980545
11/01/21 12:47 PM
11/01/21 12:47 PM
WH23H6
Closest Race Track
Hey , Thanks for responding. Did you have a Rear Anti Roll bar on the car? Just curious. Also.. How stable "stable" was the car at the big end? Chris
[Re: BigBlockGTS]
#2980730
11/01/21 09:42 PM
11/01/21 09:42 PM
Posts: 11,722 Portage,michigan
B3422W5
Portage,michigan
I went 1.34 and 9.80’s in a 3350 pound A body Duster. Not minitubbed, 28 by 10 tire, with cheap CE 3 way shocks all around, 002/003 super stock springs, no pinion snubber. Car was ultra consistent, would hook on ice. That said, i consider an E body a harder car to get to work because of no rear overhang like A and B bodies have. Significant liability. Were it me, making 800-1000 horsepower, and not looking to set world speed records, but trying to have a reliable car, i would move right past Calverts and go with ladder bars, or 4 link.
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
