Page 3 of 3 1 2 3
Re: 572 engine, PG or 727 trans? [Re: Cab_Burge] #2978747
10/26/21 09:18 PM
10/26/21 09:18 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I am around three ProFlites (two from A1 one from Joels,) and all of them are stock case, its the only option. FWIW they are used in cars with over 1000hp and so far knock on wood no issues. As for adapting them to other applications there are a few ways. I like the A1 adapter best myself. There was a truck pull guy working on an aftermarket case but it was HUGE and heavy not sure if it ever came to fruition.
Re: 572 engine, PG or 727 trans? [Re: JERICOGTX] #2978786
10/27/21 07:06 AM
10/27/21 07:06 AM
Yes
sixpakdodge Offline
sixpakdodge  Offline
Yes
Originally Posted by JERICOGTX
I can understand using something like that when it comes to Class racing, and a 727 case is required, but in a Bracket car, I see no reason it's a better option? How much does a trans like that cost? Seems like no one wants to say...
I've been told by Super Stock guys to budget $6-8k for a Proflite. Used ones seem to go for $3500-5k. At the same time, I was also privy to a conversation where a Mopar S/S racer claimed to have $30k in switching over from a 727 to a Liberty.
As far as the SFI case, I never heard anything more about it either. I believe the truck puller who was doing them was from Missouri or thereabout? I'm not sure if any were ever cast, but there were CAD drawings for them. It was definitely investigated.
Re: 572 engine, PG or 727 trans? [Re: sixpakdodge] #2978790
10/27/21 07:17 AM
10/27/21 07:17 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Quote
=sixpakdodge At the same time, I was also privy to a conversation where a Mopar S/S racer claimed to have $30k in switching over from a 727 to a Liberty.
I can guarantee it doesn't cost 30K to install a Liberty in a car. Weighing out my options, and a well built TH400 was $3500 more then a Liberty, after adding every single thing up.
69 GTX 68 Road Runner
Re: 572 engine, PG or 727 trans? [Re: JERICOGTX] #2978810
10/27/21 09:23 AM
10/27/21 09:23 AM
Boynton Beach, Fl
Rapid588 Offline
Rapid588  Offline
Boynton Beach, Fl
I saw a post on F.book a while back from the truck puller guys that were going to have SFI cases for the torqueflites built, said it was DOA due to the company they were going to get the cases from had been contacting many transmission companies also trying to get someone to bite, so they dropped it.
A Lot of us would love to get an SFI case, I have a lot of good parts that would really like a stronger case around them .... we have a few cars with up to 1400 hp behind them, with no real breakage,
but yes... there needs to be a stronger SFI case made.
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: 572 engine, PG or 727 trans? [Re: Rapid588] #2978818
10/27/21 09:50 AM
10/27/21 09:50 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
This is where going to PRI makes a difference. I talked with a manufacturer of SFI trans cases, and asked if they had any plans to build a SFI case 727. They told me I was the first one to ask about it. People can talk about them all they want, but face to face time with the companies that actually make stuff is where it's at. That question needs to be asked over and over.
Re: 572 engine, PG or 727 trans? [Re: JERICOGTX] #2978887
10/27/21 12:22 PM
10/27/21 12:22 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
If it was affordable, Rick Allison would do it.
Re: 572 engine, PG or 727 trans? [Re: R3 Racing] #2979023
10/27/21 08:16 PM
10/27/21 08:16 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I seem to recall that the case guy was in contact with Keith Long. Part of the reason it fell apart was the guy couldn't find a foundry in the US that would work with the small volume this guy wanted.
Re: 572 engine, PG or 727 trans? [Re: slantzilla] #2979148
10/28/21 08:20 AM
10/28/21 08:20 AM
an8sec70cuda Offline
Go powerglide and don't look back. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: 572 engine, PG or 727 trans? [Re: Rapid588] #2979174
10/28/21 09:31 AM
10/28/21 09:31 AM
gregsdart Offline
gregsdart  Offline
Would a 727 case from a diesel application be a possibility? Guys have been running some serious torque through these I believe, and torque is what breaks things.
Re: 572 engine, PG or 727 trans? [Re: gregsdart] #2979183
10/28/21 09:56 AM
10/28/21 09:56 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Who has broke a stock 727 case from any reason other than sprag failure? If so, at what power level?
Doug
Re: 572 engine, PG or 727 trans? [Re: dvw] #2979186
10/28/21 10:02 AM
10/28/21 10:02 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
I believe most want the aftermarket case for its SFI certification….. no more ill fitting or unobtanium trans shields. At least that’s all I can see as a need for them in the 727 circles.
Page 3 of 3 1 2 3
