Are all KYB gas-a-just shocks the same? #2976000
10/19/21 09:22 AM
10/19/21 09:22 AM
IL
furious70 Offline OP
IL
So I bought a set of 4 for my 68 Charger off ebay, but they sent me the wrong rear shocks:
KG5466 were sent, which is for midsize 4x4 vs
KG5512
dimensionally they are close, but not the same, but is the valving also going to be different or are they all just the same inside? The ebay retailer says 'they are all the same', but that's just a random seller on ebay of course
KG5466
Extended Length 22.95
Compressed Length 14.09
Stroke Length 8.86
KG5512
Extended Length 22.64
Compressed Length 13.98
Stroke Length 8.66
but I don't see any info about valving or vehicle weight assumptions
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Are all KYB gas-a-just shocks the same? [Re: furious70] #2976035
10/19/21 10:51 AM
10/19/21 10:51 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
KG5512
KG5466
Stroke Length 8.86
KG5512
Stroke Length 8.66
Don't trust a random Ebay seller, but will trust a random internet poster?
Always go to the source
From KYB
https://www.kyb.com/resources/technical-information/dimensions/
Re: Are all KYB gas-a-just shocks the same? [Re: furious70] #2976036
10/19/21 10:53 AM
10/19/21 10:53 AM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Not sure of the answer, but I just removed the KYB's off the front of my 68 Charger, they are WAY to stiff on compression, could feel every little bump,ripple in the road, it drove great but gave a VERY rough ride in the front, I put some cheap monroe matics on & it is smooth as glass now, BUT handling was better with the KYB, but my car was built for street strip & running on the highway not corner carving
Re: Are all KYB gas-a-just shocks the same? [Re: Sniper] #2976039
10/19/21 10:56 AM
10/19/21 10:56 AM
IL
IL
KG5512
KG5466
Stroke Length 8.86
KG5512
Stroke Length 8.66
From KYB
I guess none of us should ask questions here then?
I did go to KYB, that's how I got the dimensions I shared. Your link helped me with top/bottom mounts, which also aren't the same, so thank you for that.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Are all KYB gas-a-just shocks the same? [Re: CSK] #2976041
10/19/21 10:57 AM
10/19/21 10:57 AM
IL
IL
I've got the monroe 'wave makers' today and the car is far to floaty and bottoms out on bumps far to easily for my tastes.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Are all KYB gas-a-just shocks the same? [Re: furious70] #2976055
10/19/21 11:30 AM
10/19/21 11:30 AM
Pattison Texas
Pattison Texas
I like your term WAVE MAKERS LOL, & yes they are, my car sits very low in the front I have not had any bottoming out as of yet, I have a large sway bar on the front & a smaller adjustable one on the rear & the RT torsion bars .920 I think is the size, I diffidently liked the handling of the KYB over the monroe's, but I sure like running 80 mph & up with a smoother ride.
Re: Are all KYB gas-a-just shocks the same? [Re: furious70] #2976063
10/19/21 11:51 AM
10/19/21 11:51 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
KG5512
KG5466
Stroke Length 8.86
KG5512
Stroke Length 8.66
From KYB
I guess none of us should ask questions here then? If you want opinion ask here, you want facts go to KYB
Guess you missed the part where they say "Choosing a shock absorber for a particular application must include component performance (damping rate) capabilities in addition to dimensions and mountings."
Re: Are all KYB gas-a-just shocks the same? [Re: Sniper] #2976071
10/19/21 12:11 PM
10/19/21 12:11 PM
IL
IL
That info wasn't even required since the mounting is not the same, that's more than enough 'proof' for me to file my claim with ebay that the seller didn't ship what he sold. That vague claim on the KYB site isn't going to mean anything to ebay, physical dimensions and mount points different will. That KYB page would be very useful if it had the valving specs as well, but that's probably IP they don't want to publish.
Didn't mean to piss in your Wheaties, my apologies.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: Are all KYB gas-a-just shocks the same? [Re: furious70] #2976173
10/19/21 06:05 PM
10/19/21 06:05 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
THE OP's question should have been "do all KYB shocks suck?"
Based on over 20 years on these forums, then the correct answer would be "no", but very rarely.
Valving is not the core issue here. KYB just seems to be clueless. twocents
Re: Are all KYB gas-a-just shocks the same? [Re: furious70] #2976226
10/19/21 07:50 PM
10/19/21 07:50 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If you want valving specs you have to call them, like it says om the page I linked. I called them in the 90's to get the rates on a set of A body spec shocks.
As for the mounting thing, you didn't ask for that but glad you found what you really needed to sort it out.
BTW, see what I mean about opinions here? and my wheaties are unfazed
