Re: Question on 1969 440 A-bodies
[Re: Diego (not Ted)]
#2975952
10/19/21 01:51 AM
10/19/21 01:51 AM
Posts: 21,522 N.E. OHIO, USA
A12
N.E. OHIO, USA
Do I have this straight?
--Built with 383s but special-order M in the VIN, then sent to Hurst in Madison Heights
--Limited warranty (12/12)
--No PS even though the 383 had it as an option - correct no room for power steering pump and different driver's side engine mount
--All console automatics (why console mandatory?) - Probably because no room for column shift linkage to automatic only trans
--3.55 standard, 3.91 optional - correct
--Manual drum brakes - correct, again no room for power brake booster?
Did I miss anything pertinent? Thank you! Automatic only because 440 engine required Dana for 4-speed trans and no Dana available that was narrow enough for the A-body at the time. Specific 383/440 A-body radiator with bottom radiator hose outlet spout relocated slightly to clear oil filterSpecial or specific driver's side exhaust manifold for clearance of steering column and (?)Mike
[Re: A12]
#2975959
10/19/21 03:47 AM
10/19/21 03:47 AM
Posts: 4,798 Castlegar, BC, Canada
That AMC Guy
I read the console auto only was due to there being no room for the column shift linkage to fit.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
#2976016
10/19/21 10:05 AM
10/19/21 10:05 AM
Posts: 43,575 Round Lake Beach, Illinoisy
Rhinodart
Rhinotruck
Rhinotruck
Yes you missed the most important point, they WERE assembled at the Hamtramck plant and NOT sent outside, please do not perpetuate that old wives tale... The 48 Mr. Norms 440 GSS Darts and the 6 factory Super Stock 68 Darts were assembled at Hurst-Campbell...
JB Rhinehart, Realist
A-Body's RULE!
[Re: That AMC Guy]
#2976067
10/19/21 12:02 PM
10/19/21 12:02 PM
A12
N.E. OHIO, USA
I read the console auto only was due to there being no room for the column shift linkage to fit. Never read that but I figured that was the reason Mike Originally Posted by Diego (not Ted) Do I have this straight? --Built with 383s but special-order M in the VIN, then sent to Hurst in Madison Heights --Limited warranty (12/12) --No PS even though the 383 had it as an option - correct no room for power steering pump and different driver's side engine mount--All console automatics (why console mandatory?) - Probably because no room for column shift linkage to automatic only trans (A12 wrote ) --3.55 standard, 3.91 optional - correct--Manual drum brakes - correct, again no room for power brake booster? Did I miss anything pertinent? Thank you!
[Re: Rhinodart]
#2976309
10/19/21 10:18 PM
10/19/21 10:18 PM
Posts: 22,900 Gabba Gabba Hey! NYC
Diego (not Ted)
Yes you missed the most important point, they WERE assembled at the Hamtramck plant and NOT sent outside, please do not perpetuate that old wives tale... The 48 Mr. Norms 440 GSS Darts and the 6 factory Super Stock 68 Darts were assembled at Hurst-Campbell... Y'know, I had heard there was some misinformation going on for years but thought it may have been the '68s. Thanks for the clarification. Funny thing is that I think I got it right in my book.
[Re: 330Scott]
#2976421
10/20/21 10:02 AM
10/20/21 10:02 AM
Rhinodart
Rhinotruck
Rhinotruck
This one was at the Mopar show in Dubuque Iowa in August. Were they all radio delete?
No, the majority of them had a radio.
A-Body's RULE!
