Question on 1969 440 A-bodies #2975946
10/19/21 01:08 AM
10/19/21 01:08 AM
Gabba Gabba Hey! NYC
Diego (not Ted) Offline OP
Do I have this straight?
--Built with 383s but special-order M in the VIN, then sent to Hurst in Madison Heights
--Limited warranty (12/12)
--No PS even though the 383 had it as an option
--All console automatics (why console mandatory?)
--3.55 standard, 3.91 optional
--Manual drum brakes
Did I miss anything pertinent? Thank you!
Re: Question on 1969 440 A-bodies [Re: Diego (not Ted)] #2975952
10/19/21 01:51 AM
10/19/21 01:51 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
--No PS even though the 383 had it as an option - correct no room for power steering pump and different driver's side engine mount
--All console automatics (why console mandatory?) - Probably because no room for column shift linkage to automatic only trans
--3.55 standard, 3.91 optional - correct
--Manual drum brakes - correct, again no room for power brake booster?
Automatic only because 440 engine required Dana for 4-speed trans and no Dana available that was narrow enough for the A-body at the time.
Specific 383/440 A-body radiator with bottom radiator hose outlet spout relocated slightly to clear oil filter
Special or specific driver's side exhaust manifold for clearance of steering column and (?)
Mike
Re: Question on 1969 440 A-bodies [Re: A12] #2975954
10/19/21 02:07 AM
10/19/21 02:07 AM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
Radiator hose routing to water pump may also have been a concern or issue for power steering??? Pretty tight on the driver's side between the 440 engine, firewall and inner fender. My M-code Dart like probably a few that wanted headers had to cut the fender wells and head out that way to get a good performing set.
Re: Question on 1969 440 A-bodies [Re: A12] #2975959
10/19/21 03:47 AM
10/19/21 03:47 AM
Castlegar, BC, Canada
That AMC Guy Offline
I read the console auto only was due to there being no room for the column shift linkage to fit.
Bloody Mary, Full of Vodka, Blessed art thou among cocktails....
Re: Question on 1969 440 A-bodies [Re: Diego (not Ted)] #2976016
10/19/21 10:05 AM
10/19/21 10:05 AM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
Yes you missed the most important point, they WERE assembled at the Hamtramck plant and NOT sent outside, please do not perpetuate that old wives tale... tsk The 48 Mr. Norms 440 GSS Darts and the 6 factory Super Stock 68 Darts were assembled at Hurst-Campbell...
JB Rhinehart, Realist
A-Body's RULE!
Re: Question on 1969 440 A-bodies [Re: That AMC Guy] #2976067
10/19/21 12:02 PM
10/19/21 12:02 PM
N.E. OHIO, USA
A12 Offline
A12  Offline
N.E. OHIO, USA
up Never read that but I figured that was the reason up
Mike
--All console automatics (why console mandatory?) - Probably because no room for column shift linkage to automatic only trans (A12 wrote wink )
Re: Question on 1969 440 A-bodies [Re: Rhinodart] #2976309
10/19/21 10:18 PM
10/19/21 10:18 PM
Y'know, I had heard there was some misinformation going on for years but thought it may have been the '68s. Thanks for the clarification.
Funny thing is that I think I got it right in my book. grin
Re: Question on 1969 440 A-bodies [Re: Diego (not Ted)] #2976341
10/20/21 01:00 AM
10/20/21 01:00 AM
Eyewa
330Scott Offline
330Scott  Offline
Eyewa
This one was at the Mopar show in Dubuque Iowa in August. Were they all radio delete?
Re: Question on 1969 440 A-bodies [Re: 330Scott] #2976421
10/20/21 10:02 AM
10/20/21 10:02 AM
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
No, the majority of them had a radio.
A-Body's RULE!
Re: Question on 1969 440 A-bodies [Re: Rhinodart] #2983314
11/09/21 02:34 AM
11/09/21 02:34 AM
