440 Motor ID Question. #2975066
10/16/21 04:50 PM
10/16/21 04:50 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
Looking at buying a U code 73 Charger SE. The motor block is blank in the VIN pad area. Casting year of the block is difficult to read but cast part number is the later 73-78 440. Top of motor assembly pad picture is attached. Assy. date is 2 23 but there appears to be no letter in front of the 440 stamp identifying the year.
Warranty replacement?
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor
1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic
1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow
1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top
2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue
2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black
2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 440 Motor ID Question. [Re: TimS] #2975115
10/16/21 07:09 PM
10/16/21 07:09 PM
AndyF Offline
AndyF  Offline
I don't think there is any way of knowing with just that information. The ID pad appears to be original based on the wide machining grooves. The stamping doesn't follow the normal pattern but it was a manual process so maybe it was the guys first day on the job and he just screwed it up. If you buy the car you'll probably find more clues that lead you to a final conclusion. The date codes on various engine parts can also help point the way. If the intake manifold, cylinder heads, water pump housing, etc. all have date codes which slightly precede the engine assembly date and the engine assembly date is slightly before the vehicle assembly date then it is probably all original.
Re: 440 Motor ID Question. [Re: AndyF] #2975182
10/16/21 10:35 PM
10/16/21 10:35 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
My understanding is that warranty blocks were stamped either S440 or just a 440 without a preceding letter designating the year. This car I’m looking at should also have the HP stamped in that pad location. This one does not. The motor however does have the correct manifold and heads for 73. Likely removed from the original motor and placed on the new short block. Another tid bit. The SPD of the car is 919, Sep 19 1973. Motor stamp date is 2 23.
Re: 440 Motor ID Question. [Re: TimS] #2975200
10/17/21 12:39 AM
10/17/21 12:39 AM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
Truck motors didn't have the vin stamped on them.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 440 Motor ID Question. [Re: moparmarks] #2975219
10/17/21 06:42 AM
10/17/21 06:42 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’ve got a later warranty short block that I could look at but the 73 HP block I have has a J440 and the HP on the same line but way over to the right more.
Re: 440 Motor ID Question. [Re: moparmarks] #2975236
10/17/21 08:40 AM
10/17/21 08:40 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
I believe truck motors had a T stamped in front of the 440. I've had a T440 and T400 that were in trucks.
Re: 440 Motor ID Question. [Re: TimS] #2975239
10/17/21 08:44 AM
10/17/21 08:44 AM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
My thinking initially on this motor was that it could have been a mistake at the factory not having the VIN stamp but the upper pad confirms that it is not original to the car, it appears to me.
Now just need to confirm that casting year somehow. I think the owner is going to work on that just for his own knowledge, which is good.
Re: 440 Motor ID Question. [Re: TimS] #2975259
10/17/21 10:15 AM
10/17/21 10:15 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I don't believe a warranty block exists. Warranty short blocks do. If it's a warranty short block it should have the warranty tag over a casting hole. If it was just an over the counter replacement block, all the ones I've seen have no stamping at all. Just my twocents
Re: 440 Motor ID Question. [Re: 6PakBee] #2975308
10/17/21 12:13 PM
10/17/21 12:13 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
The over the counters you’ve seen, are they stamped on the upper pad or just blank all over. Upper and lower(VIN area) blank?
Re: 440 Motor ID Question. [Re: TimS] #2975315
10/17/21 12:57 PM
10/17/21 12:57 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
There are no numbers stamped anywhere on the blocks I've seen. The one exception that I've personally seen is on an over the counter Hemi block. I have a 1974 cast date NOS block that has the 'WT' stamped on the upper pad.
Re: 440 Motor ID Question. [Re: TimS] #2975330
10/17/21 01:50 PM
10/17/21 01:50 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
the "T" is for Trenton, MI the location of the engine assembly plant & I believe started for the 1974 model year - clean that top pad & figure what the casting date is on the engine
Re: 440 Motor ID Question. [Re: TimS] #2975333
10/17/21 01:57 PM
10/17/21 01:57 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
a '73 Charger would not be scheduled 9/19/73 - that would be '74 model year production - a block for a 9/19/72 Charger would be #2536430 cast 1972 or earlier
Re: 440 Motor ID Question. [Re: 6bblgt] #2975383
10/17/21 05:10 PM
10/17/21 05:10 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
The casting date is on the side of block in raised cast numbers
Re: 440 Motor ID Question. [Re: 6bblgt] #2975405
10/17/21 07:15 PM
10/17/21 07:15 PM
Walton, Indiana
TimS Offline OP
TimS  Offline OP
Walton, Indiana
This is a WP29U3A car with a 914 (my mistake on the day. It is 14 not 19)SPD. No doubt a 73. Original fender tag and broadcast sheet shows this.
