440 Motor ID Question.
#2975066
10/16/21 04:50 PM
10/16/21 04:50 PM
Posts: 2,179 Walton, Indiana
TimS
Walton, Indiana
Looking at buying a U code 73 Charger SE. The motor block is blank in the VIN pad area. Casting year of the block is difficult to read but cast part number is the later 73-78 440. Top of motor assembly pad picture is attached. Assy. date is 2 23 but there appears to be no letter in front of the 440 stamp identifying the year.
Warranty replacement?
Thanks.
1968 Barracuda Fastback 318-2BBL 904 2.76 Frost Blue Survivor 1970 Roadrunner 440+6 BBL 727 AT 4.10 SG Dana Blue Fire Metallic 1971 Cuda 340-4 BBL 4spd 3.91 SG Curious Yellow 1972 Barracuda 318-2 BBL 904 AT 3.23 1 Legger Tor Red/White Vinyl Top 2007 Dodge Ram 1500 5.7 Hemi AT Patriot Blue 2011 Dodge Challenger RT 5.7 Hemi 6spd 392 SG Triple Black 2014 Dodge Charger RT Max AWD 5.7 Hemi AT 305 Billet Silver
Re: 440 Motor ID Question.
[Re: AndyF]
#2975182
10/16/21 10:35 PM
10/16/21 10:35 PM
TimS
Walton, Indiana
My understanding is that warranty blocks were stamped either S440 or just a 440 without a preceding letter designating the year. This car I’m looking at should also have the HP stamped in that pad location. This one does not. The motor however does have the correct manifold and heads for 73. Likely removed from the original motor and placed on the new short block. Another tid bit. The SPD of the car is 919, Sep 19 1973. Motor stamp date is 2 23.
[Re: moparmarks]
#2975219
10/17/21 06:42 AM
10/17/21 06:42 AM
Posts: 6,389 Abilene, Texas
fastmark
Abilene, Texas
I’ve got a later warranty short block that I could look at but the 73 HP block I have has a J440 and the HP on the same line but way over to the right more.
[Re: moparmarks]
#2975236
10/17/21 08:40 AM
10/17/21 08:40 AM
TimS
Walton, Indiana
Truck motors didn't have the vin stamped on them. I believe truck motors had a T stamped in front of the 440. I've had a T440 and T400 that were in trucks.
[Re: TimS]
#2975239
10/17/21 08:44 AM
10/17/21 08:44 AM
TimS
Walton, Indiana
My thinking initially on this motor was that it could have been a mistake at the factory not having the VIN stamp but the upper pad confirms that it is not original to the car, it appears to me.
Now just need to confirm that casting year somehow. I think the owner is going to work on that just for his own knowledge, which is good.
[Re: 6PakBee]
#2975308
10/17/21 12:13 PM
10/17/21 12:13 PM
TimS
Walton, Indiana
I don't believe a warranty block exists. Warranty short blocks do. If it's a warranty short block it should have the warranty tag over a casting hole. If it was just an over the counter replacement block, all the ones I've seen have no stamping at all. Just my The over the counters you’ve seen, are they stamped on the upper pad or just blank all over. Upper and lower(VIN area) blank?
[Re: TimS]
#2975315
10/17/21 12:57 PM
10/17/21 12:57 PM
Posts: 10,706 North Dakota
6PakBee
North Dakota
I don't believe a warranty block exists. Warranty short blocks do. If it's a warranty short block it should have the warranty tag over a casting hole. If it was just an over the counter replacement block, all the ones I've seen have no stamping at all. Just my The over the counters you’ve seen, are they stamped on the upper pad or just blank all over. Upper and lower(VIN area) blank? There are no numbers stamped anywhere on the blocks I've seen. The one exception that I've personally seen is on an over the counter Hemi block. I have a 1974 cast date NOS block that has the 'WT' stamped on the upper pad.
[Re: TimS]
#2975330
10/17/21 01:50 PM
10/17/21 01:50 PM
Posts: 17,516 Las Vegas, NV
6bblgt
Las Vegas, NV
Truck motors didn't have the vin stamped on them. I believe truck motors had a T stamped in front of the 440. I've had a T440 and T400 that were in trucks. the "T" is for Trenton, MI the location of the engine assembly plant & I believe started for the 1974 model year - clean that top pad & figure what the casting date is on the engine
[Re: TimS]
#2975333
10/17/21 01:57 PM
10/17/21 01:57 PM
6bblgt
Las Vegas, NV
My understanding is that warranty blocks were stamped either S440 or just a 440 without a preceding letter designating the year. This car I’m looking at should also have the HP stamped in that pad location. This one does not. The motor however does have the correct manifold and heads for 73. Likely removed from the original motor and placed on the new short block. Another tid bit. The SPD of the car is 919, Sep 19 1973. Motor stamp date is 2 23. a '73 Charger would not be scheduled 9/19/73 - that would be '74 model year production - a block for a 9/19/72 Charger would be #2536430 cast 1972 or earlier
[Re: 6bblgt]
#2975405
10/17/21 07:15 PM
10/17/21 07:15 PM
TimS
Walton, Indiana
My understanding is that warranty blocks were stamped either S440 or just a 440 without a preceding letter designating the year. This car I’m looking at should also have the HP stamped in that pad location. This one does not. The motor however does have the correct manifold and heads for 73. Likely removed from the original motor and placed on the new short block. Another tid bit. The SPD of the car is 919, Sep 19 1973. Motor stamp date is 2 23. a '73 Charger would not be scheduled 9/19/73 - that would be '74 model year production - a block for a 9/19/72 Charger would be #2536430 cast 1972 or earlier This is a WP29U3A car with a 914 (my mistake on the day. It is 14 not 19)SPD. No doubt a 73. Original fender tag and broadcast sheet shows this.
