motor plate #297419
04/23/09 01:44 PM
04/23/09 01:44 PM
hudson valley n.y.
GEORGE68HEMIRR Offline OP
super street
super street
hudson valley n.y.
i would have posted this on question and answer but i figured that was for stock.....water pump gaskets or copper spray or silocone.....i have aluminum water pump,motor plate, aluminum block....what works best?.....the last time i did this i used gaskets and high tack permatex gasket sealant....it didnt last long....does anybody have better luck with something else?...thanks
Re: motor plate [Re: GEORGE68HEMIRR] #297420
04/23/09 01:54 PM
04/23/09 01:54 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
We just use black RTV silicone and let it cure 100% before adding liquid or heat cycling.Let it set 24 hours and retighten bolts.
Re: motor plate [Re: GEORGE68HEMIRR] #297421
04/23/09 02:19 PM
04/23/09 02:19 PM
AndyF Offline
AndyF  Offline
I like the water pump gaskets from Cometic. They are a multi-layer gasket and if you're lucky, you can reuse them a few times.
Re: motor plate [Re: GEORGE68HEMIRR] #297422
04/23/09 03:33 PM
04/23/09 03:33 PM
Central Oregon
Rodney Offline
Rodney  Offline
Central Oregon
I use fel pro gaskets and a little sealer and have studs in the block to make it easier to install everything, makes alignment a breeze.
Re: motor plate [Re: Rodney] #297423
04/23/09 03:54 PM
04/23/09 03:54 PM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i've been making my own water pump gaskets from some card that came with one of my job sheet books. i smear synthetic grease on them before bolting up. not one has ever let me down, more than i can say for the professional gasket makers gaskets.
Re: motor plate [Re: B G Racing] #297424
04/23/09 03:59 PM
04/23/09 03:59 PM
Greenville, South Carolina
BBLM23 Offline
BBLM23  Offline
I agree. It sucks to win the 2nd round and get told I watered the track at the time slip booth. Luckily it rained before the 3rd round. I put black silicone on and let it sit overnight. Filled it Sunday morning and went 4 rounds. I never use gaskets on the Dart anymore...
Walter
1969 Dart Swinger w/ARC Pump Gas 493 B1/BS 10.18 at 130mph
Racing Pro in street trim.
1981 Aries ARC 548 B1 8.88 at 147mph (footbraking)
1996 Ram 2500 V10 16.52 at 80mph
1981 Reliant 400
Re: motor plate [Re: BBLM23] #297425
04/23/09 04:27 PM
04/23/09 04:27 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
couldn't get gaskets to live with this set up ,started using Right Stuff no problems since!
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: motor plate [Re: 65dragnet] #297426
04/23/09 07:25 PM
04/23/09 07:25 PM
hudson valley n.y.
super street
super street
hudson valley n.y.
thanks guys ...sounds like black rtv is what i am doing
