Antenna has gone too far down..
#2973075
10/11/21 03:44 PM
10/11/21 03:44 PM
Posts: 7,540 Albany, NY
67SATisfaction
The member whose name is actually Art
Albany, NY
Hey all,
Anyone know how to get an antenna back up, that has gone too far down? The "ball" tip of my antenna came off, and the top segment of the telescoping antenna got pushed too far down to use the tip to pull it up..
1965 Satellite. I can't figure out if I can disassemble it.. I think that would destroy it.. Any ideas? Can I get into it from the inside, use a thin rod to push it up.. .. or just buy new repop..
Thanks, - Art
65 Satellite hardtop 361/4bbl console 727 2.76 67 Satellite convert 383/2bbl column 727 3.23 67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd 67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd 71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd 82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle 75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF 77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF 07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Antenna has gone too far down..
[Re: 67SATisfaction]
#2973387
10/12/21 12:23 PM
10/12/21 12:23 PM
Posts: 4,724 Moved to N.E. Tennessee
GomangoCuda
Just spitballing here but maybe you could make a long thin hook out of thin music wire, slide it down inside the top segment, hook the bottom and pull it up. maybe, maybe not.
[Re: Sniper]
#2973651
10/12/21 07:22 PM
10/12/21 07:22 PM
GomangoCuda
I've used a small tap to lightly thread in and pull it out. that should work. Heck even a drywall screw might work.
[Re: GomangoCuda]
#2976435
10/20/21 11:00 AM
10/20/21 11:00 AM
67SATisfaction
Albany, NY
Sorry for the delayed Thank You, I'll try a couple different approaches.. that top segment is about 1/16" in gauge..
But it seems the top segment has stopped against something and I *should* be able to push a teeny tiny tap into it, thanks for that idea..
And yes - if a tap isn't small enough, I could try drilling a tiny hole, and probably grab into it with a tiny sheetmetal screw and pull it up...
I'll report back if I get any results.. - Art
[Re: stumpy]
#2976623
10/20/21 09:16 PM
10/20/21 09:16 PM
67SATisfaction
Albany, NY
Thanks Stumpy, It's not at all hard to remove from the fender, and I did try that method after pulling as much antenna cable as I could out of the fender.. I whipped it as hard as I could, but the friction in that top piece is enough to keep it stuck good in the tube.
One more thing though - I wonder if I collapse all the tubes, maybe the the top segment will be pushed up if it "bottoms out" at the bottom fixture. I'll try that tomorrow before I drill. Cheers, - Art
