Antenna has gone too far down.. #2973075
10/11/21 03:44 PM
10/11/21 03:44 PM
Albany, NY
67SATisfaction Offline OP
The member whose name is actually Art
Albany, NY
Hey all,
Anyone know how to get an antenna back up, that has gone too far down? The "ball" tip of my antenna came off, and the top segment of the telescoping antenna got pushed too far down to use the tip to pull it up..
1965 Satellite. I can't figure out if I can disassemble it.. I think that would destroy it.. Any ideas? Can I get into it from the inside, use a thin rod to push it up..
.. or just buy new repop..
Thanks,
- Art
65 Satellite hardtop 361/4bbl console 727 2.76
67 Satellite convert 383/2bbl column 727 3.23
67 Lancia Fulvia Sport 1.3 Zagato. Alloy body, 1.3L V4 DOHC 4-spd
67 Lancia Fulvia Rallye 1.3. Alloy panel, 1.3L V4 DOHC 4-spd
71 Alfa Romeo GT Junior 1300 Zagato, 1.3L 4cyl DOHC hemi 5-spd
82 Alfa Romeo GTV6 2.5L SOHC hemi V6 5-spd transaxle
75 Maserati Bora US spec 4.9L DOHC hemi V8 5-spd ZF
77 Maserati Khamsin Euro spec 4.9L DOHC hemi V8 5-spd ZF
07 Aston Martin DB9 6.0L DOHC V12 6spd transaxle
Re: Antenna has gone too far down.. [Re: 67SATisfaction] #2973387
10/12/21 12:23 PM
10/12/21 12:23 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Just spitballing here but maybe you could make a long thin hook out of thin music wire, slide it down inside the top segment, hook the bottom and pull it up. maybe, maybe not.
Re: Antenna has gone too far down.. [Re: GomangoCuda] #2973419
10/12/21 12:52 PM
10/12/21 12:52 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I've used a small tap to lightly thread in and pull it out.
Re: Antenna has gone too far down.. [Re: Sniper] #2973651
10/12/21 07:22 PM
10/12/21 07:22 PM
GomangoCuda Offline
GomangoCuda  Offline
up that should work. Heck even a drywall screw might work.
Re: Antenna has gone too far down.. [Re: GomangoCuda] #2976435
10/20/21 11:00 AM
10/20/21 11:00 AM
Albany, NY
Albany, NY
Sorry for the delayed Thank You, I'll try a couple different approaches.. that top segment is about 1/16" in gauge..
But it seems the top segment has stopped against something and I *should* be able to push a teeny tiny tap into it, thanks for that idea..
And yes - if a tap isn't small enough, I could try drilling a tiny hole, and probably grab into it with a tiny sheetmetal screw and pull it up...
I'll report back if I get any results..
- Art
Re: Antenna has gone too far down.. [Re: 67SATisfaction] #2976448
10/20/21 11:56 AM
10/20/21 11:56 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
If it's not to hard you can remove it and then give it a quick EASY snap like a whip to pop the antenna up.
Re: Antenna has gone too far down.. [Re: stumpy] #2976623
10/20/21 09:16 PM
10/20/21 09:16 PM
Albany, NY
Albany, NY
Thanks Stumpy,
It's not at all hard to remove from the fender, and I did try that method after pulling as much antenna cable as I could out of the fender.. I whipped it as hard as I could, but the friction in that top piece is enough to keep it stuck good in the tube.
One more thing though - I wonder if I collapse all the tubes, maybe the the top segment will be pushed up if it "bottoms out" at the bottom fixture. I'll try that tomorrow before I drill.
Cheers,
- Art
Re: Antenna has gone too far down.. [Re: 67SATisfaction] #2981551
11/04/21 02:38 AM
11/04/21 02:38 AM
Perth, Western Australia
Shoominati23 Offline
Please stay on topic. tsk
