727 experts, is this factory? #2971669
10/07/21 11:57 AM
10/07/21 11:57 AM
IA
TLT Offline OP
TLT  Offline OP
IA
This a hole drilled into the side of the valve body casting where the high pressure spring goes. 1969 valve body with the plastic comb and no part throttle kickdown. I don't recall seeing that before and was wondering if it is factory
Re: 727 experts, is this factory? [Re: TLT] #2971811
10/07/21 06:48 PM
10/07/21 06:48 PM
Guitar Jones Offline
A better picture would help. That one looks like you took it with a potato.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: 727 experts, is this factory? [Re: Guitar Jones] #2971821
10/07/21 07:06 PM
10/07/21 07:06 PM
Super Spudsville
Mr PotatoHead Online rolleyes
Half Baked
Mr PotatoHead  Online Rolleyes
Half Baked
Super Spudsville
HEY!!!!!
Thats pics nuts though, seriously who can tell anything from that...... snap a good one.
But its look like a hole in a casting that might not be helping you.
STOP POTATO HATE!
Re: 727 experts, is this factory? [Re: Guitar Jones] #2971828
10/07/21 07:27 PM
10/07/21 07:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
LMAO !!!!!! smile what kind of Potato ?????
Re: 727 experts, is this factory? [Re: CSK] #2971838
10/07/21 07:53 PM
10/07/21 07:53 PM
IA
TLT Offline OP
TLT  Offline OP
IA
Hey guys, I knew I'd get crap for the picture!! That's the only way I could get the picture under the file size limitation that Moparts has on the pictures!
Re: 727 experts, is this factory? [Re: TLT] #2971839
10/07/21 07:55 PM
10/07/21 07:55 PM
IA
TLT Offline OP
TLT  Offline OP
IA
And after 28 1/2 google searches on how to change the picture/file size, I gave up, guess I'm too old for this high-tech crap!
Re: 727 experts, is this factory? [Re: TLT] #2971854
10/07/21 08:38 PM
10/07/21 08:38 PM
A727Tflite Offline
A727Tflite  Offline
I think you too close to the part. Back away a bit.
Re: 727 experts, is this factory? [Re: Guitar Jones] #2971862
10/07/21 08:45 PM
10/07/21 08:45 PM
North Seattle, Washington. USA
U code RR Offline
U code RR  Offline
Thanks! That pic reminded me that I have an eye Dr. appointment!
When seconds count... The Police are only minutes away. Smith and Wesson are your friends.
Re: 727 experts, is this factory? [Re: U code RR] #2971888
10/07/21 09:46 PM
10/07/21 09:46 PM
IA
TLT Offline OP
TLT  Offline OP
IA
Try this picture
Re: 727 experts, is this factory? [Re: TLT] #2971917
10/08/21 12:42 AM
10/08/21 12:42 AM
Nebraska
4406bbl Offline
4406bbl  Offline
Nebraska
That is not factory, some shift kits did that mod for increased pressure relief, it also included a different spring for that. Pretty sure transgo did that in the 70s. It should be an 1/8" hole, that one looks bigger.
Re: 727 experts, is this factory? [Re: 4406bbl] #2972050
10/08/21 01:32 PM
10/08/21 01:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yeah, that's a Transgo TF-2 mod; should have a white spring on the check ball.
Re: 727 experts, is this factory? [Re: John_Kunkel] #2972054
10/08/21 01:40 PM
10/08/21 01:40 PM
IA
TLT Offline OP
TLT  Offline OP
IA
Thanks guys, I appreciate it!!!
Re: 727 experts, is this factory? [Re: TLT] #2972098
10/08/21 03:36 PM
10/08/21 03:36 PM
S E Michigan
E
ekim Offline
ekim  Offline
E
S E Michigan
stupid question-
did that hole have to have a drain back valve was it plugged ?
Re: 727 experts, is this factory? [Re: ekim] #2972104
10/08/21 04:11 PM
10/08/21 04:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
On the pre-'66 there was a stamped steel pump check valve over that pocket, on the '69-later there is a high pressure relief valve (ball) in the pocket. The factory relief channel is fairly small and won't flow much volume so the drilled hole is added to provide more flow.
Re: 727 experts, is this factory? [Re: John_Kunkel] #2972131
10/08/21 05:27 PM
10/08/21 05:27 PM
IA
TLT Offline OP
TLT  Offline OP
IA
Thanks John!, so that hole just adds more pressure all the time (line pressure?) or just during shifts? Just trying to understand a very (to me) complicated system!
Re: 727 experts, is this factory? [Re: TLT] #2972235
10/08/21 10:12 PM
10/08/21 10:12 PM
VA
dragon slayer Offline
VA
It is the relief of pressure, not higher pressure. When pump pressure too high the ball is moved off the port and the fluid flows out the channel and that hole. So it makes sure that pressure is relieved.
Re: 727 experts, is this factory? [Re: TLT] #2972391
10/09/21 12:43 PM
10/09/21 12:43 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The factory says the relief ball is to relieve pressure when Reverse is engaged and the fluid is cold. In Reverse, the line pressure increases by a factor of about three, so line pressure can exceed 300 psi under those circumstances and that much pressure can bust parts...especially the rear band and its linkage.
Re: 727 experts, is this factory? [Re: John_Kunkel] #2972473
10/09/21 06:52 PM
10/09/21 06:52 PM
IA
TLT Offline OP
TLT  Offline OP
IA
Makes sense now, reverse is always a hard hit! Thanks guys, I appreciate it!!
