Re: 727 experts, is this factory?
[Re: TLT]
#2971811
10/07/21 06:48 PM
10/07/21 06:48 PM
Guitar Jones
A better picture would help. That one looks like you took it with a potato.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
[Re: Guitar Jones]
#2971821
10/07/21 07:06 PM
10/07/21 07:06 PM
Posts: 9,451 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
HEY!!!!!
Thats pics nuts though, seriously who can tell anything from that...... snap a good one.
But its look like a hole in a casting that might not be helping you.
STOP POTATO HATE!
[Re: Guitar Jones]
#2971828
10/07/21 07:27 PM
10/07/21 07:27 PM
Posts: 2,856 Pattison Texas
CSK
Pattison Texas
A better picture would help. That one looks like you took it with a potato. LMAO !!!!!! what kind of Potato ?????
[Re: U code RR]
#2971888
10/07/21 09:46 PM
10/07/21 09:46 PM
Posts: 60 IA
TLT
IA
[Re: 4406bbl]
#2972050
10/08/21 01:32 PM
10/08/21 01:32 PM
Posts: 25,783 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yeah, that's a Transgo TF-2 mod; should have a white spring on the check ball.
[Re: ekim]
#2972104
10/08/21 04:11 PM
10/08/21 04:11 PM
John_Kunkel
Rio Linda, CA
On the pre-'66 there was a stamped steel pump check valve over that pocket, on the '69-later there is a high pressure relief valve (ball) in the pocket. The factory relief channel is fairly small and won't flow much volume so the drilled hole is added to provide more flow.
[Re: TLT]
#2972391
10/09/21 12:43 PM
10/09/21 12:43 PM
John_Kunkel
Rio Linda, CA
The factory says the relief ball is to relieve pressure when Reverse is engaged and the fluid is cold. In Reverse, the line pressure increases by a factor of about three, so line pressure can exceed 300 psi under those circumstances and that much pressure can bust parts...especially the rear band and its linkage.
