Re: 727 experts, is this factory?
[Re: TLT]
#2971811
10/07/21 06:48 PM
10/07/21 06:48 PM
Posts: 20,660 in a cattle trailer down by th...
Guitar Jones
A better picture would help. That one looks like you took it with a potato.
[Re: Guitar Jones]
#2971821
10/07/21 07:06 PM
10/07/21 07:06 PM
Posts: 9,554 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
HEY!!!!!
Thats pics nuts though, seriously who can tell anything from that...... snap a good one.
But its look like a hole in a casting that might not be helping you.
STOP POTATO HATE!
[Re: Guitar Jones]
#2971828
10/07/21 07:27 PM
10/07/21 07:27 PM
Posts: 2,871 Pattison Texas
CSK
Pattison Texas
A better picture would help. That one looks like you took it with a potato. LMAO !!!!!! what kind of Potato ?????
[Re: U code RR]
#2971888
10/07/21 09:46 PM
10/07/21 09:46 PM
Posts: 60 IA
TLT
IA
[Re: 4406bbl]
#2972050
10/08/21 01:32 PM
10/08/21 01:32 PM
Posts: 25,949 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Yeah, that's a Transgo TF-2 mod; should have a white spring on the check ball.
[Re: ekim]
#2972104
10/08/21 04:11 PM
10/08/21 04:11 PM
John_Kunkel
Rio Linda, CA
On the pre-'66 there was a stamped steel pump check valve over that pocket, on the '69-later there is a high pressure relief valve (ball) in the pocket. The factory relief channel is fairly small and won't flow much volume so the drilled hole is added to provide more flow.
[Re: TLT]
#2972391
10/09/21 12:43 PM
10/09/21 12:43 PM
John_Kunkel
Rio Linda, CA
The factory says the relief ball is to relieve pressure when Reverse is engaged and the fluid is cold. In Reverse, the line pressure increases by a factor of about three, so line pressure can exceed 300 psi under those circumstances and that much pressure can bust parts...especially the rear band and its linkage.
