Critique This Spark Plug
#2971516
10/06/21 08:56 PM
10/06/21 08:56 PM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
This plug came directly from a low deck 498” engine with dyno time only. Had 7 pulls on it and would like your expertise on anything you can surmise. 13:1 comp., sunoco Blue fuel 112 octane, pretty even egt across using a Wilson moded Intake. Pulls to 7900. Thx
Re: Critique This Spark Plug
[Re: Chargerfan68]
#2971758
10/07/21 04:24 PM
10/07/21 04:24 PM
Posts: 43,193 Bend,OR USA
Cab_Burge
What does the ground strap look like? Does that fuel normally look yellow on the porclyn?
[Re: Cab_Burge]
#2971798
10/07/21 06:11 PM
10/07/21 06:11 PM
Chargerfan68
New York, USA
340….thanks for that link. Very informative. He is a Force for sure! What does the ground strap look like? Does that fuel normally look yellow on the porclyn? Cab….not sure on that fuel looking yellow, but all 8 plugs looked the same. Here is the strap before dismantling:
[Re: Chargerfan68]
#2972045
10/08/21 01:22 PM
10/08/21 01:22 PM
Cab_Burge
That looks a little rich to me How much timing and what heat range is that plug?
[Re: Cab_Burge]
#2972067
10/08/21 02:11 PM
10/08/21 02:11 PM
Chargerfan68
New York, USA
That looks a little rich to me How much timing and what heat range is that plug? That’s what i was thinking, but wanted more experienced opinions. Thx. I do like the idea of it being just on the rich/safe side. Timing at 35 with a -1 Indy head chamber. Ngk R5672A-8 plug on recommendation.
[Re: 340Cuda]
#2972068
10/08/21 02:13 PM
10/08/21 02:13 PM
Posts: 9,841 MI, usa
dvw
MI, usa
5/8" hole saw without the drill bit cuts them easily. Doug
