Critique This Spark Plug #2971516
10/06/21 08:56 PM
10/06/21 08:56 PM
New York, USA
Chargerfan68 Offline OP
New York, USA
This plug came directly from a low deck 498” engine with dyno time only. Had 7 pulls on it and would like your expertise on anything you can surmise. 13:1 comp., sunoco Blue fuel 112 octane, pretty even egt across using a Wilson moded Intake. Pulls to 7900. Thx
Re: Critique This Spark Plug [Re: Chargerfan68] #2971644
10/07/21 10:25 AM
10/07/21 10:25 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I think Steve Morris would say it is a little rich:
https://www.youtube.com/watch?v=MecCoercp-s
Re: Critique This Spark Plug [Re: Chargerfan68] #2971758
10/07/21 04:24 PM
10/07/21 04:24 PM
What does the ground strap look like?
Does that fuel normally look yellow on the porclyn?
Re: Critique This Spark Plug [Re: Cab_Burge] #2971798
10/07/21 06:11 PM
10/07/21 06:11 PM
New York, USA
New York, USA
340….thanks for that link. Very informative. He is a Force for sure!
Cab….not sure on that fuel looking yellow, but all 8 plugs looked the same.
Here is the strap before dismantling:
Re: Critique This Spark Plug [Re: Chargerfan68] #2971948
10/08/21 08:59 AM
10/08/21 08:59 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Learn something new all the time. Never knew you could separate the plug like that. Do you just twist them apart with some pliers?
Re: Critique This Spark Plug [Re: 80fbody] #2971972
10/08/21 10:05 AM
10/08/21 10:05 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
You either get a tool or cut them apart on a lath. May be other ways, don't know.
https://nitrousoutlet.com/i-30560870-spark-plug-cutting-tool.html
Re: Critique This Spark Plug [Re: Chargerfan68] #2972016
10/08/21 11:53 AM
10/08/21 11:53 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
It may be a little rich if you are digging for maximum power, but I would say it is just right if it came out of one of my engines, I like a little rich just to be safe, plus you don't need to be changing jets if it happens to be a cool day at the track.
Re: Critique This Spark Plug [Re: Chargerfan68] #2972045
10/08/21 01:22 PM
10/08/21 01:22 PM
That looks a little rich to me shruggy
How much timing and what heat range is that plug?
Re: Critique This Spark Plug [Re: Cab_Burge] #2972067
10/08/21 02:11 PM
10/08/21 02:11 PM
New York, USA
New York, USA
That’s what i was thinking, but wanted more experienced opinions. Thx. I do like the idea of it being just on the rich/safe side.
Timing at 35 with a -1 Indy head chamber. Ngk R5672A-8 plug on recommendation.
Re: Critique This Spark Plug [Re: 340Cuda] #2972068
10/08/21 02:13 PM
10/08/21 02:13 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
5/8" hole saw without the drill bit cuts them easily.
Doug
Re: Critique This Spark Plug [Re: Chargerfan68] #2972136
10/08/21 05:49 PM
10/08/21 05:49 PM
I would try a #7 plug next up twocents
Re: Critique This Spark Plug [Re: dvw] #2972370
10/09/21 11:46 AM
10/09/21 11:46 AM
moparx Offline
moparx  Offline
Doug
iagree
available at most hardware stores, and no more than about $15, even if you have to buy the mandrel.
beer
