RB Performer RPM #2970279
10/04/21 11:11 AM
10/04/21 11:11 AM
West Palm Beach, Florida
Copper Dart Offline OP
Has anyone ever done this before? Fitting the new intake, it teeter's on the corners of the steel valley pan/intake gasket. Reliefing the corners allowed the intake to seat much better and didn't require pressing a hard 90* into the outer corners of the steel gasket, The gasket sealer fills the very small and softer corner just fine. I hope this doesn't open a oil leak issue on my build.
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: RB Performer RPM [Re: Copper Dart] #2970282
10/04/21 11:14 AM
10/04/21 11:14 AM
Kirkland, Washington
Pacnorthcuda Offline
Interference at the corners should always be checked…with ANY manifold. Relieving a bit is not uncommon.
Re: RB Performer RPM [Re: Copper Dart] #2970285
10/04/21 11:19 AM
10/04/21 11:19 AM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
If you wouldn’t of checked that or seen
You would have been wondering why your going thru quarts of oil getting sucked into the intake ports of your heads , along with the possibly of oil fouled spark plugs
Not necessarily a leak on the outside , but definetly internal
Good catch
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: RB Performer RPM [Re: Pacnorthcuda] #2970291
10/04/21 11:27 AM
10/04/21 11:27 AM
Thanks, I hadn't noticed any other manifolds relieved in that way before. I feel much better knowing someone smarter/more experienced than myself approves of the modification to fit it better. bow Thanks
Copper
Mom.
Ricky Valdes
Re: RB Performer RPM [Re: bee1971] #2970296
10/04/21 11:33 AM
10/04/21 11:33 AM
Good catch
bow Not to mention the tuning headaches and possible ruining an O2 sensor mixture monitor. up You guys are great answering all of my questions.
Copper
Mom.
Ricky Valdes
Re: RB Performer RPM [Re: Copper Dart] #2970543
10/04/21 08:07 PM
10/04/21 08:07 PM
I took some pictures of the bolt hole alignment scopeon both sides after relieving the corners of the intake manifold. You couldn't ask for a better alignment and fit! up
Copper
Mom.
Ricky Valdes
Re: RB Performer RPM [Re: Copper Dart] #2970587
10/04/21 09:50 PM
10/04/21 09:50 PM
Cab_Burge Online work
Cab_Burge  Online Work
Some of the stock valley pan steel hold downs have a beveled edge on one side on both ends scope
It does the same thing for clearing the intake ends up scope
Re: RB Performer RPM [Re: Cab_Burge] #2970599
10/04/21 10:30 PM
10/04/21 10:30 PM
Yes sir and thank you bow, I noticed the bevel (hard to see on the picture) and installed it face up.
Copper
Mom.
Ricky Valdes
