RB Performer RPM
#2970279
10/04/21 11:11 AM
10/04/21 11:11 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
Has anyone ever done this before? Fitting the new intake, it teeter's on the corners of the steel valley pan/intake gasket. Reliefing the corners allowed the intake to seat much better and didn't require pressing a hard 90* into the outer corners of the steel gasket, The gasket sealer fills the very small and softer corner just fine. I hope this doesn't open a oil leak issue on my build.
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: RB Performer RPM
[Re: Copper Dart]
#2970285
10/04/21 11:19 AM
10/04/21 11:19 AM
Posts: 2,810 Sobieski Wi
bee1971
Sobieski Wi
If you wouldn’t of checked that or seen
You would have been wondering why your going thru quarts of oil getting sucked into the intake ports of your heads , along with the possibly of oil fouled spark plugs Not necessarily a leak on the outside , but definetly internal
Good catch
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: Pacnorthcuda]
#2970291
10/04/21 11:27 AM
10/04/21 11:27 AM
Copper Dart
Interference at the corners should always be checked…with ANY manifold. Relieving a bit is not uncommon. Thanks, I hadn't noticed any other manifolds relieved in that way before. I feel much better knowing someone smarter/more experienced than myself approves of the modification to fit it better. Thanks Copper
[Re: bee1971]
#2970296
10/04/21 11:33 AM
10/04/21 11:33 AM
Copper Dart
Good catch Not to mention the tuning headaches and possible ruining an O2 sensor mixture monitor. You guys are great answering all of my questions. Copper
[Re: Copper Dart]
#2970543
10/04/21 08:07 PM
10/04/21 08:07 PM
Copper Dart
I took some pictures of the bolt hole alignment on both sides after relieving the corners of the intake manifold. You couldn't ask for a better alignment and fit! Copper
[Re: Cab_Burge]
#2970599
10/04/21 10:30 PM
10/04/21 10:30 PM
Copper Dart
Some of the stock valley pan steel hold downs have a beveled edge on one side on both ends It does the same thing for clearing the intake ends Yes sir and thank you , I noticed the bevel (hard to see on the picture) and installed it face up. Copper
