Re: converting 85 D150 to an AC truck
[Re: volaredon]
#2968130
09/28/21 12:13 PM
09/28/21 12:13 PM
Posts: 2,105 Byron, NY
W.I.N. Racing
Byron, NY
For proper opperation you need a A/C dash. Or you need to do some custom vents. If not it will just blow teh cold air under the dash.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#2968158
09/28/21 01:32 PM
09/28/21 01:32 PM
Posts: 2,225 ILLINOIS
volaredon
ILLINOIS
For proper opperation you need a A/C dash. Or you need to do some custom vents. If not it will just blow teh cold air under the dash. I gotta take the dash out to swap out the plenum anyway, was hoping for some kind of marking on the backside where I could cut out the vents to fit in. The VIN is with the dash on these, and my dash is in real good shape so I wanted to retain it in the conversion if it would be possible
[Re: volaredon]
#2968265
09/28/21 10:02 PM
09/28/21 10:02 PM
Posts: 20,630 in a cattle trailer down by th...
Guitar Jones
You don't have to remove the dash to get the box in or out. The dash is not marked for the vents but when we added A/C to those trucks at the dealership we had templates on where to cut the dash for the vents. Those vents pop in and out. Just drilled the four corners then used a soldering gun with a flat blade tip to cut the dash.
'92 D250 Club Cab CTD, 47RH conversion, pump tweaks, injectors, rear disc and hydroboost conversion. '74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon! 2019 1500 Long Horn Crew Cab 4WD, 5.7 Hemi.
