loctite or a spot of weld ? #2967531
09/26/21 03:10 PM
09/26/21 03:10 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
I dodged a bullet last weekend when the screw holding the butterfly to the throttle shaft fell out. Found the screw on top of the #5 intake valve ! Weighing my options to not risk this again. Would you just put it back in with red locktite and keep an eye on it ? Or , since the screw is made of what appears to be stainless and the shaft steel, simply put a small spot of weld on it ? I'm not worried about the need to ever dis-assemble it, but concerned the weld process might warp the shaft. Thoughts ? Is there a better option ?
Re: loctite or a spot of weld ? [Re: cagebob1] #2967536
09/26/21 03:34 PM
09/26/21 03:34 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
Dang you were lucky , I would use the locktight myself. I have never been that accurate at that type of welding. So for me it's a no brainer. LOL Locktite and check it every once in a while. My 2 cents
6.50 @105.26
Re: loctite or a spot of weld ? [Re: cagebob1] #2967547
09/26/21 04:03 PM
09/26/21 04:03 PM
Andrews,In. U.S.of A.
67_Satellite Offline
A softer screw and stake or peen the threaded end after torqueing. How the hell did that screw not go through the engine?Lucky.
Re: loctite or a spot of weld ? [Re: 67_Satellite] #2967555
09/26/21 04:18 PM
09/26/21 04:18 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
"How the hell did that screw not go through the engine?" I honestly don't know the answer to that question. As you can see from the pic, the throttle plate is still partially open. I became aware of this when i took my foot off the gas after a 140+ mph pass, shut the motor off at 6900+ rpms. I think I used up all of my engine's 9 lives at 1 time !!!
Re: loctite or a spot of weld ? [Re: Kindafast] #2967562
09/26/21 04:46 PM
09/26/21 04:46 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
I agree. A drop of Red loctite. I hardly ever use the green, but that’s just me. Having a stick car, ever bolt and nut has RED on it. Better safe than sorry.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: loctite or a spot of weld ? [Re: 67_Satellite] #2967570
09/26/21 05:29 PM
09/26/21 05:29 PM
twocents scope wrench Stake it or silver solder it
Re: loctite or a spot of weld ? [Re: Cab_Burge] #2967583
09/26/21 05:59 PM
09/26/21 05:59 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Something I have done on bicycle chainring bolts to keep them from loosening up is to wrap a revolution or two of teflon plumbers tape around the threads. It puts them in just enough tension that they won't back out unless you put a wrench on them the whole way until they are apart, and when you do need to take them apart again it's easier to get apart and clean up vs loctite.
Re: loctite or a spot of weld ? [Re: cagebob1] #2967588
09/26/21 06:11 PM
09/26/21 06:11 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Another vote for red Loctite.
Re: loctite or a spot of weld ? [Re: John_Kunkel] #2967660
09/26/21 11:20 PM
09/26/21 11:20 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I worry about staking the screw without the proper fixture, too easy to screw up the shaft or butterfly.
What I do when re-assembling during a rebuild is to take a pair of pliers or your vise to
deform the threads SLIGHTLY for an interference fit, this has served me well.
My 2 cents, Joe
PS That's the screw threads, not the shaft
