Re: loctite or a spot of weld ?
[Re: cagebob1]
#2967536
09/26/21 03:34 PM
09/26/21 03:34 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
Dang you were lucky , I would use the locktight myself. I have never been that accurate at that type of welding. So for me it's a no brainer. LOL Locktite and check it every once in a while. My 2 cents
6.50 @105.26
[Re: Kindafast]
#2967562
09/26/21 04:46 PM
09/26/21 04:46 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
I agree. A drop of Red loctite. I hardly ever use the green, but that’s just me. Having a stick car, ever bolt and nut has RED on it. Better safe than sorry.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: Cab_Burge]
#2967583
09/26/21 05:59 PM
09/26/21 05:59 PM
Posts: 20,543 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Something I have done on bicycle chainring bolts to keep them from loosening up is to wrap a revolution or two of teflon plumbers tape around the threads. It puts them in just enough tension that they won't back out unless you put a wrench on them the whole way until they are apart, and when you do need to take them apart again it's easier to get apart and clean up vs loctite.
[Re: cagebob1]
#2967588
09/26/21 06:11 PM
09/26/21 06:11 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Another vote for red Loctite.
[Re: John_Kunkel]
#2967660
09/26/21 11:20 PM
09/26/21 11:20 PM
Posts: 1,317 Ohio
jlatessa
Ohio
I worry about staking the screw without the proper fixture, too easy to screw up the shaft or butterfly.
What I do when re-assembling during a rebuild is to take a pair of pliers or your vise to deform the threads SLIGHTLY for an interference fit, this has served me well.
My 2 cents, Joe
PS That's the screw threads, not the shaft
