vibration question 360 auto
#296727
04/22/09 07:42 PM
04/22/09 07:42 PM
Posts: 421 massachusetts
Provan
massachusetts
360 motor 727 b&m flex plate for 360, ger converter with no weights.. have a vibration around 2000 to 2500 rpm when in park, and also under acceleration around the same rpm.. pop into neutral while driving, and no vibration..all new u joints .any ideas? thanks
76 DODGE VAN PRO STREET
67 DODGE CORONET R/T 480 STROKER
Re: vibration question 360 auto
[Re: Provan]
#296728
04/22/09 09:35 PM
04/22/09 09:35 PM
Posts: 7,506 Az
Crizila
Az
Don't know what you have changed recently ( if anything - besides the u-joints - which didn't solve the problem ) to get the vibration, but you could try unbolting the convertor and rotating it 180 degrees and bolting it back up. The flex plate does have a big bite out of it for external balanced engines right? Got a big hunk of iron hanging off the trans tailshaft? That was Chryslers cure for a vibration in about that rpm range on some vehicles.
Fastest 300
[Re: Crizila]
#296732
04/24/09 10:44 PM
04/24/09 10:44 PM
Posts: 5,791 Hamilton, Ontario Canada
Magnum
The drive plate to torque convertor bolts/lugs have one lug offset to NOT allow mixing up their indexing.
Are you sure you have the correct 360 balancer? There are 2 different ones. A LA360 and a Magnum which is 92 and up.
[Re: RapidRobert]
#296734
04/25/09 08:14 AM
04/25/09 08:14 AM
Provan
massachusetts
I got the B&M plate with the notch cutout on it to run a converter with no weights. The motor is a low mileage 29K,360 with the balancer that was on it when it was pulled out ..And I cannot spin the converter because it does only bolt on 1 way..The vibration started after I changed everything,removed the 318 and trans, and put the 360 in with a new rebuilt 727. I think I can rule out u joints and wheels, as the vibration is there when sitting in park..Maybe the converter is junk. its a GER, and I guess they are out of business?
