vibration question 360 auto #296727
04/22/09 07:42 PM
04/22/09 07:42 PM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
360 motor 727 b&m flex plate for 360, ger converter with no weights.. have a vibration around 2000 to 2500 rpm when in park, and also under acceleration around the same rpm.. pop into neutral while driving, and no vibration..all new u joints .any ideas? thanks
76 DODGE VAN PRO STREET 67 DODGE CORONET R/T 480 STROKER
Re: vibration question 360 auto [Re: Provan] #296728
04/22/09 09:35 PM
04/22/09 09:35 PM
Az
Crizila Offline
Crizila  Offline
Az
Don't know what you have changed recently ( if anything - besides the u-joints - which didn't solve the problem ) to get the vibration, but you could try unbolting the convertor and rotating it 180 degrees and bolting it back up. The flex plate does have a big bite out of it for external balanced engines right? Got a big hunk of iron hanging off the trans tailshaft? That was Chryslers cure for a vibration in about that rpm range on some vehicles.
Fastest 300
Re: vibration question 360 auto [Re: Provan] #296729
04/24/09 04:14 PM
04/24/09 04:14 PM
Utah
O
orangemonster Offline
super gas
super gas
O
Utah
You probably know this but 360's are externally balanced,heavier dampner and weights on the convertor.Since yours does'nt have the weights that is probably it.And check and see if your u-joints are centered in the yoke.
Re: vibration question 360 auto [Re: Crizila] #296730
04/24/09 08:41 PM
04/24/09 08:41 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Good luck with that trick.
Don't be the exception.
Re: vibration question 360 auto [Re: orangemonster] #296731
04/24/09 08:58 PM
04/24/09 08:58 PM
Az
Crizila Offline
Crizila  Offline
Az
If he already bought the B&M flex plate for a 360, it is made to be run with a non-weighted convertor, which he has. He should be all set there. Cheap aftermarket convertors can have a balance problem - hence rotate it 180 and see if that helps. If he put the u-joint "C" clips in properly, they should be centered. Good to check though.
Fastest 300
Re: vibration question 360 auto [Re: Crizila] #296732
04/24/09 10:44 PM
04/24/09 10:44 PM
Hamilton, Ontario Canada
Magnum Offline
Magnum  Offline
The drive plate to torque convertor bolts/lugs have one lug offset to NOT allow mixing up their indexing.
Are you sure you have the correct 360 balancer?
There are 2 different ones. A LA360 and a Magnum which is 92 and up.
Re: vibration question 360 auto [Re: Provan] #296733
04/24/09 10:55 PM
04/24/09 10:55 PM
any ideas?
Yes, has it always had that vibration or did it start recently?
Re: vibration question 360 auto [Re: RapidRobert] #296734
04/25/09 08:14 AM
04/25/09 08:14 AM
massachusetts
P
Provan Offline OP
Provan  Offline OP
P
massachusetts
I got the B&M plate with the notch cutout on it to run a converter with no weights. The motor is a low mileage 29K,360 with the balancer that was on it when it was pulled out ..And I cannot spin the converter because it does only bolt on 1 way..The vibration started after I changed everything,removed the 318 and trans, and put the 360 in with a new rebuilt 727. I think I can rule out u joints and wheels, as the vibration is there when sitting in park..Maybe the converter is junk. its a GER, and I guess they are out of business?
Re: vibration question 360 auto [Re: Magnum] #296735
04/25/09 08:36 AM
04/25/09 08:36 AM
Az
Crizila Offline
Crizila  Offline
Az
HMMM - I'll have to check mine again, Thought the indexing was drive plate to crank only on external balance B&M plates. Don't understand why you would have to index a convertor to the drive plate with no external weights on the convertor? It's been a while since the 408 I've been running for the last 3 yrs is internal balanced - forget a lot at my age.
Fastest 300
Re: vibration question 360 auto [Re: Provan] #296736
04/25/09 08:42 AM
04/25/09 08:42 AM
that would be my thinking. It's a nonmagnum 360 that ran good when pulled(no vibration I'm sure)harmonic dampener wasn't changed(would be no reason to), the correct flex plate(The one for an externally bal 360 with a neutral 727 converter) was used. R&R the converter.
Re: vibration question 360 auto [Re: RapidRobert] #296737
04/25/09 08:45 AM
04/25/09 08:45 AM
Az
Crizila Offline
Crizila  Offline
Az
Fastest 300
Re: vibration question 360 auto [Re: Crizila] #296738
04/30/09 09:36 AM
04/30/09 09:36 AM
Magnum Offline
Magnum  Offline
Both the crank to plate and the plate to convetor need to be indexed because it's not actually the plate that needs to be indexed (in a factory app). It's the convertor to crank that need to be indexed.
Re: vibration question 360 auto [Re: Magnum] #296739
04/30/09 10:58 AM
04/30/09 10:58 AM
Az
Crizila Offline
Crizila  Offline
Az
Checked mine - your right - sorry about that.
Fastest 300
