Installing my camshaft 2* advanced #2966581
09/23/21 08:37 AM
09/23/21 08:37 AM
West Palm Beach, Florida
Copper Dart Offline OP
I'm installing my camshaft 2* advanced. What should I expect? Any guess of HP, Torque and RPM peaks of each?
10.5:1 440 stock port Edelbrock RPM heads, Eddy performer RPM intake, headers ect.
camshaft specs in picture
Copper
Common sense, the least common of all the senses.
Mom.
For fear of ridicule, society stifles creativity.
Ricky Valdes
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966589
09/23/21 08:46 AM
09/23/21 08:46 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
are you adding 2 degrees of advance? cam already has 4 degrees of advance ground into it. so, what's the purpose for 2 more degrees?
Re: Installing my camshaft 2* advanced [Re: lewtot184] #2966619
09/23/21 10:01 AM
09/23/21 10:01 AM
I'm trying to bring the stated 6500 rpm power curve down a bit and move it to even a better bottom rpm range. Thats why I'm asking smarter people than myself.
Copper
Mom.
Ricky Valdes
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966621
09/23/21 10:10 AM
09/23/21 10:10 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
Originally Posted by Copper Dart
I'm trying to bring the stated 6500 rpm power curve down a bit and move it to even a better bottom rpm range. That's why I'm asking smarter people than myself.
Copper
2 degrees more advance will move peak power a couple hundred rpm down, but may increase cylinder pressure some due to closing the intake valve earlier. how critical is the use of pump gas? in my opinion i'd install the cam per cam card specs and work the ignition for more low end. perhaps a different cam profile would let you get closer to having your cake and eating it too.
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966655
09/23/21 11:28 AM
09/23/21 11:28 AM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Alot of times it comes in a degree on either side anyways depending on your setup and it's not typically worth the work to move it a degree for a street car. If it's coming in two degrees advanced, I wouldn't hesitate run it if it were my build. Just note it all down in a log so you can recall if you want to make a "tuning" adjustment later.
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966686
09/23/21 01:17 PM
09/23/21 01:17 PM
Are you installing it at 106, 104 or 108 ATDC on the intake lobes?
I would try installing it at 106 like recommended and go from there. twocents
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966722
09/23/21 03:34 PM
09/23/21 03:34 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Honestly, the chances of a fast rate hyd cam pulling strong up to 6500 in a BB is pretty slim.
Re: Installing my camshaft 2* advanced [Re: fast68plymouth] #2966727
09/23/21 03:52 PM
09/23/21 03:52 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
yep. i don't pay much attention to the cam grinders peak rpm/power numbers.
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966728
09/23/21 03:55 PM
09/23/21 03:55 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Always good to state the actual intake centerline in discussions. The words "straight -up", "advanced" and "retarded" have different meanings to different people.
What engine is this going in? That cam will rpm a lot different in a 383 verses a 510.
I'm not too sure that 6500 is even achievable with XE cam's in any motor.
I cannot say if putting that cam in at 104° is right for your set-up. It could be. But if you've never run this cam and you think you should run it at 104° (what I would call 6° advanced), maybe you should consider a different cam.
If you think a hydraulic cam in the 240° duration is right for your set-up, I would also suggest looking at a solid flat tappet cam.
At the end of the day, there is nothing wrong with running it at 104°. It's your call.
Re: Installing my camshaft 2* advanced [Re: BSB67] #2966774
09/23/21 06:57 PM
09/23/21 06:57 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
All of the above plus the rest of the car is also important,. A 3000# car with 4.10 gears and a good converter might love that cam but a 4000# car with 2 something gears and a 12" converter will likely hate that cam. Advancing an extra 2° won't fix that.
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966837
09/23/21 08:41 PM
09/23/21 08:41 PM
Andrews,In. U.S.of A.
67_Satellite Offline
Don't be surprised if it hits a "wall" about 5000-5500 r.p.m. Been watching a series of you tube videos about a clown building a 440 for "Mopar MaMa" which inexplicably wouldn't rev past 5k. Many missteps along their way, but I don't know if they ever figured out they pissed in their wheaties with the fast comp cams hyd, cam and 1.6 rockers,
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966841
09/23/21 08:48 PM
09/23/21 08:48 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Buy yourself a good engine program, I like Performance Tends, but there are several good ones. There are so many variables in advancing or retarding camshafts that a computer program with GOOD numbers inputed is the best way to go. I been messing with mopar engines since 1974, I never install or build any engine now mild or wild without using an engine program first.
Re: Installing my camshaft 2* advanced [Re: GomangoCuda] #2966908
09/24/21 07:22 AM
09/24/21 07:22 AM
1970 Dart Swinger, 3:55 posi, 2800 stall 727, 3" mandrel stainless to the bumper, mini tubs, 275/60 15 bfg's
I don't have a weight measurement of the car yet but I know that the 440 with aluminum heads, intake, water pump and housing, and headers weighs less than the stock 318 with P/S, A/C, iron manifolds ect., plus I removed a/c and heater boxes, power steering, all A/C components, swapped the 150# bench for seat very light import bucket seats. shruggy I'm guessing 300-400 lbs less than stock.
Mom.
Ricky Valdes
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2966911
09/24/21 07:29 AM
09/24/21 07:29 AM
Well I have been successfully scared nervous off of the fence about advancing the camshaft an additional 2* degrees and have installed it as built/ground. eek
Copper
Mom.
Ricky Valdes
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2967042
09/24/21 01:47 PM
09/24/21 01:47 PM
I've never heard of or lifted a stock A body front bench seat that weighed over 100 lbs., I did weigh several different sets of bucket seats and one stock 1971 duster front bench seat when I was putting my old pump gas Duster together, I'm thinking the 1973 Duster bucket seats combine were around 70 lbs. and the bench seat weighed a little more, maybe 8 to 15 lbs. work
The 1971 buckets weighed more,10 to 20 lbs. more for the pair than the 1973 buckets did hence me using them up
That car had a 400 stroker motor in it and was not built to be real light, it weighed 3450 Lbs. with me in it with extra padding under the carpet and above the head liner, standard steering, heater box and no back seat, five point chrome moly roll bar and a Summit brand 3.0 inch exhaust to the rear bumper.
I move the motor back right at .18 inches and move the rear end forward 1.0 inch, it had 50.6 % weight on the front and the rest (49.4%)n the rear tires with me in it boogie
It would hook up in a mud puddle in a rain storm devil up
Best ever ET was 9.993 at 134,8 MPH using Oregon 91 octane pump swill with the air cleaner and exhaust hooked up and working boogiegrin
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2967096
09/24/21 05:29 PM
09/24/21 05:29 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
Copper
i think that's a good decision. run it, tune it, and then make a decision about installed centerline, especially with a cam with advance already ground into it. if pump gas is a concern with 10.5:1 compression i don't think i'd want the intake valve closing sooner than the stated 68 degrees ABDC. the suggestion about a solid lifter cam is very sound. you will find a solid cam to have more flexibility. big hydraulic cams just add to the misery index.
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2967098
09/24/21 05:43 PM
09/24/21 05:43 PM
AndyF Online content
AndyF  Online Content
My guess is that you'll never be able to tell the difference but that shouldn't stop you from going ahead and trying it. I've played with installed position on the dyno (using a Jesel belt drive to make the task easier) and I've never seen a big difference. What does seem to have some truth in it is the old rule of installing the cam so the intake opening and exhaust closing events are evenly centered around TDC. In your case, that would require installing the cam at 109 so the intake opens at 35 and the exhaust closes at 35. But 110 with the intake at 36 and the exhaust at 34 is probably close enough.
Re: Installing my camshaft 2* advanced [Re: fast68plymouth] #2967109
09/24/21 06:27 PM
09/24/21 06:27 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
[quote=fast68plymouth]Honestly, the chances of a fast rate hyd cam pulling strong up to 6500 in a BB is pretty slim. [/quote
What’s your reason? spring, lifter float or harmonics? Reason being I took out a cam from a 383 that did 6500 then into a stock low compression 440 that was hard to get to 5000. Tried 3 sets of springs and no change. 509 cam. Ideas?
To the op I agree run it the way it came.
Re: Installing my camshaft 2* advanced [Re: Copper Dart] #2967135
09/24/21 08:35 PM
09/24/21 08:35 PM
saint paul mn.
johnzgarage Offline
johnzgarage  Offline
saint paul mn.
Ya, I think i get what your trying to do by lowering the total rpm on the torque/power curve. Is this just driven on the street ? or is it raced ?
Re: Installing my camshaft 2* advanced [Re: johnzgarage] #2967147
09/24/21 09:00 PM
09/24/21 09:00 PM
Correct, just street driven and I just wanted the power/torque a bit lower in the rpm range. Swapping our and breaking in another flat tappet cam that's better suited for my application/wants just doesn't seem worth the effort, risk or cost. This all came about because I have the engine apart to replace some gaskets and freshen up the paint and detail. Uncovering the timing chain and knowing that the crank gear has the advance/retard keyways started the ideas in my little head so....
Copper
Mom.
Ricky Valdes
