572 B1 org Part 5 - Build Notes
#2966856
09/23/21 10:05 PM
09/23/21 10:05 PM
Posts: 16,926 NC
440Jim
NC
This topic is 572 B1 org Part 5 - Build Notes Here is my plan for posting progress:
572 B1 org Part 1-Buying Parts 572 B1 org Part 2-Component Observations 572 B1 org Part 3-Machine Shop Report 572 B1 org Part 4-Mock-ups 572 B1 org Part 5-Build Notes 572 B1 org Part 6-Dyno Results 572 B1 org Part 7-Track Testing
Engine Summary: 572 CID (4.500” bore x 4.500” stroke) 14.3 CR Approximately 14.7 CR (final CR will be after measuring piston to deck during assembly) B1 original Heads, CNC Ported 429/326 cfm at 0.800” lift, milled to 60cc chambers, 332cc intake ports, 125cc exhaust ports T&D paired rocker arms 1.7 ratio, part number 8013, 5/8” shafts B1 cast single 4-barrel intake manifold with RB spacers. ICON Elite forged Pistons # IC433CAKTS.std with rings & 0.185” wall Trend wrist pins, 1.355 Compression height, -6.5cc net relief, lateral gas ported Rings 0.043" top SS with CrN, 1/16" Napier 2nd, 3/16" oil ring Cometic 5-layer MLS head gaskets 4.530” dia x 0.056” thick Cam duration 282/295 at 0.050”, 0.800” lift, 113 LSA 7/16 dia Comp Cams 8649 pushrods, 9.800” long, 0.165” wall, ball-ball ends, pushrod oiling 2-1/4” primary headers with 4” collectors
Re: 572 B1 org Part 5 - Build Notes
[Re: 440Jim]
#2966864
09/23/21 10:17 PM
09/23/21 10:17 PM
Posts: 16,926 NC
440Jim
NC
Part 5 – Main Cap Install (tool). Build NotesI use this main cap install tool to press the caps straight down. I made this when I had the KB aluminum block. It makes installing main caps with the side bolts easy. And since I don't have to tap the caps with a hammer, the bearing shells stay in place during installation. The plates that bolt to the oil pan rail have a series of holes to align each cap position with the press.
[Re: 440Jim]
#2966880
09/24/21 12:14 AM
09/24/21 12:14 AM
Posts: 609 Boise
Moparteacher
Boise
Part 5 – Main Cap Install (tool). Build NotesI use this main cap install tool to press the caps straight down. I made this when I had the KB aluminum block. It makes installing main caps with the side bolts easy. And since I don't have to tap the caps with a hammer, the bearing shells stay in place during installation. The plates that bolt to the oil pan rail have a series of holes to align each cap position with the press. That's pretty slick. Thanks for sharing.
[Re: 440Jim]
#2966892
09/24/21 02:04 AM
09/24/21 02:04 AM
Posts: 43,190 Bend,OR USA
Cab_Burge
I've use a plastic and rubber tip hammer I would have never thought of doing what your doing, yours is Good
[Re: 440Jim]
#2966953
09/24/21 09:49 AM
09/24/21 09:49 AM
Posts: 4,679 On the parachute mount
n20mstr
Jim i use the exact same thing to press the caps on. Also use a threaded rod with a washer and nut to pull the cap out. One thing i do you may want to do, use a scrap piece of 1/2 or thick alum between the cap and the press. Saves the cap from getting any scratches/marks on it. Not sure if it really matters but that what i have been doing
....BAD A$$ STREET CAR.....
[Re: Moparteacher]
#2967006
09/24/21 12:23 PM
09/24/21 12:23 PM
Posts: 19,408 north of coder
moparx
Part 5 – Main Cap Install (tool). Build NotesI use this main cap install tool to press the caps straight down. I made this when I had the KB aluminum block. It makes installing main caps with the side bolts easy. And since I don't have to tap the caps with a hammer, the bearing shells stay in place during installation. The plates that bolt to the oil pan rail have a series of holes to align each cap position with the press. That's pretty slick. Thanks for sharing. i say so as well !
[Re: n20mstr]
#2967012
09/24/21 12:33 PM
09/24/21 12:33 PM
Posts: 16,926 NC
440Jim
NC
Jim i use the exact same thing to press the caps on. Also use a threaded rod with a washer and nut to pull the cap out. One thing i do you may want to do, use a scrap piece of 1/2 or thick alum between the cap and the press. Saves the cap from getting any scratches/marks on it. Not sure if it really matters but that what i have been doing I use the long threaded rod to pull them also. I actually used a 3/8 threaded rod that I turned down the end on the lathe to 5/16" and rethreaded it to fit the caps. Overkill, yes... A slide hammer does work fine for removal, but since I have the main cap "bridge" it is nicer to smoothly pull the cap off.
[Re: 440Jim]
#2976892
10/21/21 04:57 PM
10/21/21 04:57 PM
Posts: 17,846 S.E. Michigan
ZIPPY
S.E. Michigan
Part 5 – Internal oil pickup block-off. Build Notes
I am using the Milodon external oil pickup lines through the oil pan, so the internal oil pickup hole needs to be blocked-off. I used a ¾” freeze plug in the BMP block hole (with Loctite), and for good measure also made a retention plate so the freeze plug could never fall into the engine. The retention plate replaces the ½ NPT adaptor that comes with the BMP block. Loctite the ¼ allen head bolts and torque to 100 lb-in. Nice detail! Did similar on the "Pre-Callies" MP/World/FCA iron. Pic added for a handy part number.
Rich H.
Esse Quam Videri
[Re: HardcoreB]
#2980845
11/02/21 11:09 AM
11/02/21 11:09 AM
Posts: 16,926 NC
440Jim
NC
Did you 'drag-check' the oil rings with a fish scale? No I did not. I probably should have done that before putting the crank in the block. I have done that before. That is the only way to be sure how much drag is from the oil rings. Some is from the tacky assembly lube in the bearings too. My previous 4.500" bore motor (in 2014) needed 25 ft-lbs to turn everything. 0.043/0.043/(3/16) Total Seal rings that are marketed as standard tension. But "standard" could be 18 lbs tension or 22 lbs etc.; I have seen some specs for low tension very from 11 to 16 lbs.
