Installing my camshaft 2* advanced
#2966581
09/23/21 08:37 AM
09/23/21 08:37 AM
Posts: 1,520 West Palm Beach, Florida
Copper Dart
I'm installing my camshaft 2* advanced. What should I expect? Any guess of HP, Torque and RPM peaks of each?
10.5:1 440 stock port Edelbrock RPM heads, Eddy performer RPM intake, headers ect. camshaft specs in picture Copper
Common sense, the least common of all the senses. Mom.
For fear of ridicule, society stifles creativity. Ricky Valdes
Re: Installing my camshaft 2* advanced
[Re: lewtot184]
#2966619
09/23/21 10:01 AM
09/23/21 10:01 AM
Copper Dart
I'm trying to bring the stated 6500 rpm power curve down a bit and move it to even a better bottom rpm range. Thats why I'm asking smarter people than myself. Copper
[Re: Copper Dart]
#2966621
09/23/21 10:10 AM
09/23/21 10:10 AM
Posts: 3,916 usa
lewtot184
usa
I'm trying to bring the stated 6500 rpm power curve down a bit and move it to even a better bottom rpm range. That's why I'm asking smarter people than myself. Copper 2 degrees more advance will move peak power a couple hundred rpm down, but may increase cylinder pressure some due to closing the intake valve earlier. how critical is the use of pump gas? in my opinion i'd install the cam per cam card specs and work the ignition for more low end. perhaps a different cam profile would let you get closer to having your cake and eating it too.
[Re: Copper Dart]
#2966686
09/23/21 01:17 PM
09/23/21 01:17 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Are you installing it at 106, 104 or 108 ATDC on the intake lobes? I would try installing it at 106 like recommended and go from there.
[Re: Copper Dart]
#2966722
09/23/21 03:34 PM
09/23/21 03:34 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Honestly, the chances of a fast rate hyd cam pulling strong up to 6500 in a BB is pretty slim.
[Re: fast68plymouth]
#2966727
09/23/21 03:52 PM
09/23/21 03:52 PM
Posts: 3,916 usa
lewtot184
usa
Honestly, the chances of a fast rate hyd cam pulling strong up to 6500 in a BB is pretty slim. yep. i don't pay much attention to the cam grinders peak rpm/power numbers.
[Re: BSB67]
#2966774
09/23/21 06:57 PM
09/23/21 06:57 PM
Posts: 4,754 Moved to N.E. Tennessee
GomangoCuda
Always good to state the actual intake centerline in discussions. The words "straight -up", "advanced" and "retarded" have different meanings to different people.
What engine is this going in? That cam will rpm a lot different in a 383 verses a 510.
I'm not too sure that 6500 is even achievable with XE cam's in any motor.
I cannot say if putting that cam in at 104° is right for your set-up. It could be. But if you've never run this cam and you think you should run it at 104° (what I would call 6° advanced), maybe you should consider a different cam.
If you think a hydraulic cam in the 240° duration is right for your set-up, I would also suggest looking at a solid flat tappet cam.
At the end of the day, there is nothing wrong with running it at 104°. It's your call.
All of the above plus the rest of the car is also important,. A 3000# car with 4.10 gears and a good converter might love that cam but a 4000# car with 2 something gears and a 12" converter will likely hate that cam. Advancing an extra 2° won't fix that.
[Re: GomangoCuda]
#2966908
09/24/21 07:22 AM
09/24/21 07:22 AM
Copper Dart
All of the above plus the rest of the car is also important,. A 3000# car with 4.10 gears and a good converter might love that cam but a 4000# car with 2 something gears and a 12" converter will likely hate that cam. Advancing an extra 2° won't fix that. 1970 Dart Swinger, 3:55 posi, 2800 stall 727, 3" mandrel stainless to the bumper, mini tubs, 275/60 15 bfg's I don't have a weight measurement of the car yet but I know that the 440 with aluminum heads, intake, water pump and housing, and headers weighs less than the stock 318 with P/S, A/C, iron manifolds ect., plus I removed a/c and heater boxes, power steering, all A/C components, swapped the 150# bench for seat very light import bucket seats. I'm guessing 300-400 lbs less than stock.
[Re: Copper Dart]
#2966911
09/24/21 07:29 AM
09/24/21 07:29 AM
Copper Dart
Well I have been successfully scared off of the fence about advancing the camshaft an additional 2* degrees and have installed it as built/ground. Copper
[Re: Copper Dart]
#2967042
09/24/21 01:47 PM
09/24/21 01:47 PM
Cab_Burge
I've never heard of or lifted a stock A body front bench seat that weighed over 100 lbs., I did weigh several different sets of bucket seats and one stock 1971 duster front bench seat when I was putting my old pump gas Duster together, I'm thinking the 1973 Duster bucket seats combine were around 70 lbs. and the bench seat weighed a little more, maybe 8 to 15 lbs. The 1971 buckets weighed more,10 to 20 lbs. more for the pair than the 1973 buckets did hence me using them That car had a 400 stroker motor in it and was not built to be real light, it weighed 3450 Lbs. with me in it with extra padding under the carpet and above the head liner, standard steering, heater box and no back seat, five point chrome moly roll bar and a Summit brand 3.0 inch exhaust to the rear bumper. I move the motor back right at .18 inches and move the rear end forward 1.0 inch, it had 50.6 % weight on the front and the rest (49.4%)n the rear tires with me in it It would hook up in a mud puddle in a rain storm Best ever ET was 9.993 at 134,8 MPH using Oregon 91 octane pump swill with the air cleaner and exhaust hooked up and working
[Re: Copper Dart]
#2967096
09/24/21 05:29 PM
09/24/21 05:29 PM
Posts: 3,916 usa
lewtot184
usa
Well I have been successfully scared off of the fence about advancing the camshaft an additional 2* degrees and have installed it as built/ground. Copper i think that's a good decision. run it, tune it, and then make a decision about installed centerline, especially with a cam with advance already ground into it. if pump gas is a concern with 10.5:1 compression i don't think i'd want the intake valve closing sooner than the stated 68 degrees ABDC. the suggestion about a solid lifter cam is very sound. you will find a solid cam to have more flexibility. big hydraulic cams just add to the misery index.
[Re: Copper Dart]
#2967098
09/24/21 05:43 PM
09/24/21 05:43 PM
Posts: 31,069 Oregon
AndyF
My guess is that you'll never be able to tell the difference but that shouldn't stop you from going ahead and trying it. I've played with installed position on the dyno (using a Jesel belt drive to make the task easier) and I've never seen a big difference. What does seem to have some truth in it is the old rule of installing the cam so the intake opening and exhaust closing events are evenly centered around TDC. In your case, that would require installing the cam at 109 so the intake opens at 35 and the exhaust closes at 35. But 110 with the intake at 36 and the exhaust at 34 is probably close enough.
[Re: johnzgarage]
#2967147
09/24/21 09:00 PM
09/24/21 09:00 PM
Copper Dart
Ya, I think i get what your trying to do by lowering the total rpm on the torque/power curve. Is this just driven on the street ? or is it raced ? Correct, just street driven and I just wanted the power/torque a bit lower in the rpm range. Swapping our and breaking in another flat tappet cam that's better suited for my application/wants just doesn't seem worth the effort, risk or cost. This all came about because I have the engine apart to replace some gaskets and freshen up the paint and detail. Uncovering the timing chain and knowing that the crank gear has the advance/retard keyways started the ideas in my little head so.... Copper
