HELP! I need an unmolested Indy 400-3 intake
#2966022
09/21/21 01:32 PM
09/21/21 01:32 PM
Posts: 248 near St Petersburg, FL
Lifsgrt
Hey, I need a 400-3 intake for my 498" Brodix headed Bonneville bullet. If you have one or know of one, please let me know. Undy does not have any available at this time. Thanks
B3 1969 Charger R/T SE, 440/727 with 3:91s running 11.07@120
Re: HELP! I need an unmolested Indy 400-3 intake
[Re: Lifsgrt]
#2966029
09/21/21 01:47 PM
09/21/21 01:47 PM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Thought I had one but it is a tall deck. Good luck with your search.
[Re: Lifsgrt]
#2966063
09/21/21 02:57 PM
09/21/21 02:57 PM
fast68plymouth
So. Burlington, Vt.
Indy manifold on B1 heads?
[Re: fast68plymouth]
#2966079
09/21/21 04:05 PM
09/21/21 04:05 PM
Posts: 3,396 Pa
Hot 340
Pa
Indy manifold on B1 heads? prob budget sportsmans
[Re: Hot 340]
#2979945
10/30/21 04:01 PM
10/30/21 04:01 PM
Lifsgrt
Actually, non-budget fully ported B1MC heads with 2.4" Ti intake valves. Ports actually too large for this application. Need a smaller port manifold that can be ported for good flow then installed with the mis-match at the head.
[Re: HardcoreB]
#2979948
10/30/21 04:06 PM
10/30/21 04:06 PM
Lifsgrt
HardcoreB, this B1 instake flows well for what it was designed and ported to do, but it was not ported for land speed racing, heavy load at speed. Car (1969 Daytona clone) ran almoat 231mph as is, but I agree turbulence at the carb had a lot to do with the problems of distro. Moroso DS-2s that grew 2 1/2" in diameter at that speed caused the final drive ratio to be way too high, compounding the problem.
Still need an uncut Indy 400-3. Thanks
[Re: Lifsgrt]
#2980060
10/30/21 09:39 PM
10/30/21 09:39 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
Are the DS2 tires allowed to run above 175.+MPH by SCTA and BNI now?
[Re: Lifsgrt]
#2980812
11/02/21 09:17 AM
11/02/21 09:17 AM
Posts: 4,101 Shelby Twp. Mi
HardcoreB
Shelby Twp. Mi
Still need an uncut Indy 400-3. Thanks I don't know how your application is any different than a NASCAR engine? Other than a restrictor motor, any intake i have even seen has been ported in a conventional way with no reduction in cross-section.
[Re: EvilB1Dart]
#2980821
11/02/21 09:44 AM
11/02/21 09:44 AM
Posts: 173 Sticky South
Rodenteliminator
Sticky South
Just talked to Hughes, none in stock and no ETA on any coming in, I am looking for one also.
Sorry honey I spent the rent
[Re: Rodenteliminator]
#2980847
11/02/21 11:17 AM
11/02/21 11:17 AM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I just thought of it but did any of you guys contact Moparts member Jack Moore He always has stuff laying around.
[Re: Cab_Burge]
#2982266
11/06/21 01:18 AM
11/06/21 01:18 AM
Lifsgrt
Are the DS2 tires allowed to run above 175.+MPH by SCTA and BNI now? Yes, no problem.
[Re: pittsburghracer]
#2982267
11/06/21 01:22 AM
11/06/21 01:22 AM
Lifsgrt
Hey, can't find a Jack Moore on here. If you can get me in touch with him I will appreciate it. Just spoke with Indy yesterday. They said the manifolds should be poured today and available in 4-6 weeks. But that is the same story they told me just over two months ago. Hopefully they will be available soon.
[Re: Lifsgrt]
#2982271
11/06/21 02:51 AM
11/06/21 02:51 AM
Cab_Burge
try Moore and Moore racing. He usually start postings his end of the year adds on here about now
[Re: Cab_Burge]
#2982274
11/06/21 06:06 AM
11/06/21 06:06 AM
Posts: 20,201 PA.
pittsburghracer
"Little"John
"Little"John
PA.
try Moore and Moore racing. He usually start postings his end of the year adds on here about now He has been listing some stuff on Facebook.
[Re: fourgearsavoy]
#2982343
11/06/21 11:57 AM
11/06/21 11:57 AM
Posts: 1,030 ohio
67mprfan
ohio
I talked to Jack last weekend and mentioned someone here was looking for a manifold , he said he'll check it not sure he got around to it judging by the previous posts
71 demon stock stroke 440/indy ez-1 running 10.10 @ 132.14 mph in the 1/4 and 6.36 @ 107.46 mph in the 1/8 not in the same weekend but It did it then I sold it. 67 Belvedere that worked it's way in the 10's
