Need help identifying these brakes
#2965013
09/17/21 02:37 PM
09/17/21 02:37 PM
Posts: 1,278 Mission BC
10sec440
Mission BC
Hello, I'm working on a 69 Dart and I have to get the correct lower ball joints. The front calipers look similar to a 73 and up setup but it has pins instead of sliders. I think they are Diplomat brakes? If so does anyone have an idea what knuckles would be used to put these on a Dart? Thanks in advance.
Re: Need help identifying these brakes
[Re: 10sec440]
#2965078
09/17/21 07:52 PM
09/17/21 07:52 PM
Posts: 5,778 ohio
ruderunner
ohio
Could be FMJ body brakes or 70 74 B E body.
Or an aftermarket swap that used Ford calipers.
Pics will help.
Angry white pureblood male
[Re: 10sec440]
#2965104
09/17/21 08:48 PM
09/17/21 08:48 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have 73 Charger brakes on my Savoy and they are pin type calipers. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Jim_Lusk]
#2965137
09/17/21 11:31 PM
09/17/21 11:31 PM
Posts: 259 n.c.
geo.
n.c.
I believe all of the late rear wheel drive cars used the slider calipers. The pin type were early 70s B/E as I understand it. last to use both may have been '75- B bodies, I found my 11.75" set up on a '76 2 door Fury with pin type calipers. The '73- A body pin types had smaller pistons than the 2.75" E and B bodies.
[Re: geo.]
#2965175
09/18/21 07:17 AM
09/18/21 07:17 AM
Posts: 5,778 ohio
ruderunner
ohio
I took pin type off a 77 B when I did my swap to big rotors.
[Re: geo.]
#2965177
09/18/21 07:30 AM
09/18/21 07:30 AM
Posts: 6,228 nowhere
Sniper
nowhere
I believe all of the late rear wheel drive cars used the slider calipers. The pin type were early 70s B/E as I understand it. last to use both may have been '75- B bodies, I found my 11.75" set up on a '76 2 door Fury with pin type calipers. The '73- A body pin types had smaller pistons than the 2.75" E and B bodies. 73 A bodies did not use pin type calipers. Sliders only. Pre 73 did use a pin type, but that would be the 4" bolt pattern setup
[Re: Sniper]
#2965319
09/18/21 06:21 PM
09/18/21 06:21 PM
Posts: 27,465 So Cal
autoxcuda
So Cal
I believe all of the late rear wheel drive cars used the slider calipers. The pin type were early 70s B/E as I understand it. last to use both may have been '75- B bodies, I found my 11.75" set up on a '76 2 door Fury with pin type calipers. The '73- A body pin types had smaller pistons than the 2.75" E and B bodies. 73 A bodies did not use pin type calipers. Sliders only. Pre 73 did use a pin type, but that would be the 4" bolt pattern setup You can mix and match pin and slider calipers and caliper adapter bracket on 73-76 A-body/73-74 E-body spindles. Same for FMJ spindles. So you really need to examine part for part what you have. Look for the Mopar Action Disc-O-Tech brake swap article online.
