440 six pack #296414
04/22/09 03:45 PM
04/22/09 03:45 PM
btomasko Offline OP
btomasko  Offline OP
Could you please tell me what # spark plugs you are using plus gap and what Mfg. also what type of ignition wires are you using. thanks
Re: 440 six pack [Re: btomasko] #296415
04/22/09 03:47 PM
04/22/09 03:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I went w/ Champion J12's. Wanted Autolite 84's but nobody seemed to have them. I'm using a MP orange box and Distrib. I set my gap at .040 oh and MSD 8mm wires.
Coming soon!!!!
Re: 440 six pack [Re: btomasko] #296416
04/22/09 03:51 PM
04/22/09 03:51 PM
depends on your heads--stock or aluminum (which use long reach) -- Lots of threads about plugs--most like NGK since Autolite went China on us
Running headers or manifolds? A few more details and these guys will dial you in.
Gap usually depends on your ignition type--too big is not good. Remember--the old Lawnmower shop can close a gap up and make any engine crank and run.
Re: 440 six pack [Re: btomasko] #296417
04/23/09 05:16 PM
04/23/09 05:16 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Iron {906} heads...Champion RJ12YC using an MSD 6-AL, MP distributor and firecore wires...Started at the recommended .035 and is now opened up to .040...
Re: 440 six pack [Re: btomasko] #296418
04/23/09 05:23 PM
04/23/09 05:23 PM
Wayne, Michigan USA
K
KryslerKid Offline
KryslerKid  Offline
K
Wayne, Michigan USA
My RR 440 6pack seemed to do well with Autolite 85's, just under .040 I think Autozone was the only place I could find them. 8mm accel wires, chrome box, factory electronic ignition...
Re: 440 six pack [Re: KryslerKid] #296419
04/23/09 06:07 PM
04/23/09 06:07 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
440Stealth heads with NGK FR5's. FBO ignitions' box and coil. Plugs gapped at .035. So far the best plugs I've had in my motor.
Re: 440 six pack [Re: Classof70Chally] #296420
04/23/09 07:05 PM
04/23/09 07:05 PM
Best reference for plug application is Mancinis website---they show exactly what NGK with every head and compression combo
Re: 440 six pack [Re: Classof70Chally] #296421
04/23/09 08:36 PM
04/23/09 08:36 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
just thought I'd show it off.
Coming soon!!!!
Re: 440 six pack [Re: Mr.Yuck] #296422
04/23/09 08:40 PM
04/23/09 08:40 PM
CT
GTX MATT Online content
GTX MATT  Online Content
CT
Swingin 72, what headers are you running?
I ran the RJ12YC Champs in the 440 in my GTX, it was EXTREMELY rich and they worked just fine.
Re: 440 six pack [Re: GTX MATT] #296423
04/23/09 09:15 PM
04/23/09 09:15 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
those are Summit brand cheapo's this thing is about 11:1. I think 12's should be ok.
Re: 440 six pack [Re: Mr.Yuck] #296424
04/23/09 09:41 PM
04/23/09 09:41 PM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I am running Eddy heads with NGK BCP6ES gapped at .045, TTI headers, MSD dist with MSD 6AL, and Firecore 50 wires.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: 440 six pack [Re: 70sixpkrt] #296425
04/24/09 08:24 AM
04/24/09 08:24 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Old Champion J11Y's,old O.E.M wires,old dual point ignition,old 906 heads,old Street Hemi grind cam.Runs like a clock.
Re: 440 six pack [Re: Mr.Yuck] #296426
04/24/09 04:20 PM
04/24/09 04:20 PM
CT
CT
Thats what I thought, never seen a picture of them I'm about to order some so I figured I'd ask.
Re: 440 six pack [Re: GTX MATT] #296427
04/24/09 04:47 PM
04/24/09 04:47 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
GTX they are pretty good. now they are only 1 3/4 but you can use ALL of your ex mani studs. get the driver side up high and come in form under the car.
